Note:
1. With RPiOs based on Debian buster CPU Speed can be improved to 1800 Mhz. But I set it to 1700
2. GB4 will not work
3. no fio on NVMe Manjaro. CPU set to stock frequency
4. @ehab
@cybertech is gonna go nuts by the end of the month.
don't forget to add me to the users for all the vpses you have i can bench them for you now and then in your memory.
Acer predator Helios 300 i5 10th gen with rtx 2060 , not the fastest but gets the job done
Which drive is this? Some Silicon Power or Timetec NVMe?
WD SN550,
pacificrack
last bench after PayPal dispute
My Raspberry Pi4,
1st Run
Tue 09 Nov 2021 07:37:02 PM IST ARM-compatibility is considered *experimental* Basic System Information: --------------------------------- Processor : Cortex-A72 CPU cores : 4 @ 1700.0000 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.5 GiB Swap : 100.0 MiB Disk : 220.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 58.62 MB/s (14.6k) | 126.06 MB/s (1.9k) Write | 58.58 MB/s (14.6k) | 129.81 MB/s (2.0k) Total | 117.21 MB/s (29.3k) | 255.87 MB/s (3.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 139.54 MB/s (272) | 79.92 MB/s (78) Write | 151.48 MB/s (295) | 89.17 MB/s (87) Total | 291.02 MB/s (567) | 169.09 MB/s (165) ARM architecture not supported by Geekbench 4, use Geekbench 5. Geekbench 4 test failed. Test truncated at this stage*2nd Run
GB5 only
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 18.40 MB/s (4.6k) | 83.05 MB/s (1.2k) Write | 18.39 MB/s (4.5k) | 85.52 MB/s (1.3k) Total | 36.80 MB/s (9.2k) | 168.58 MB/s (2.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 138.89 MB/s (271) | 144.91 MB/s (141) Write | 150.77 MB/s (294) | 161.68 MB/s (157) Total | 289.66 MB/s (565) | 306.60 MB/s (298) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 238 Multi Core | 591 Full Test | https://browser.geekbench.com/v5/cpu/10914993Comparison of fio for 64k / 4 k and 1m is very interesting !
3rd Run
YABS with Manjaro on USB NVMe
non-result
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) Geekbench 5 test failed. Run manually to determine cause.Note:
4. @ehab
blog | exploring visually |
My previous Post updated
your getting creative.
are you this romantic with the ladies?
Act.. and not just talk? With the ladies I suppose you got to do both?
yes .. i can imagine
lets talk somewhere else , @cybertech will freak if we spam here
later
Wishosting - KVM HDD Limited Flash Sale - $3.99/month
Odd write speeds since this is supposed to be a hard drive!
https://webhorizon.net
SpeedyPage - KVM-2G 2.99 GBP/month
SpeedyPage - KVM-4G 4.99 GBP/month
Posting for historical arcihves.
My INR 19 K (~ US Dollars 280) Crapware- Coconics Laptop, moments before it died for good. Planning to use it for parts.
ISP: ShockHosting
CPU: Intel(R) Xeon(R) CPU E3-1271 v3
RAM: 16GB DDR 3
DISK: 1x 480GB SSD
IP: /29 subnet
PRICE: 30€ per month
Amadex • Hosting Forums • root.hr
Small manjaro homelab vps
Most likely NVMe cache, speeds will go down once that has run out
Great for short bursts
PHP-Friends vServer Schnupperspecial 2021 NVMe
Went on a dedi buying spree with OVH, upgrading older ones.
RISE-LE-2
Game-LE
hosthatch HK
active services running
GreencloudVPS SG10GbpsStorage0.5TB
One for the road:
Greencloud BF 2020 12 GB / 4VCPU Singapore before it's curtains down this week:
new home desktop on SSD while awaiting NVMe arrival:
Upcycled ThinkCentre Tiny M900.
Waiting 16 GB RAM Stick, soon to be my media recording / editing station
(Added RAM, replaced stock KDD with SATA
Monday 22 November 2021 03:56:34 AM IST Basic System Information: --------------------------------- Processor : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz CPU cores : 4 @ 2500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 15.5 GiB Swap : 8.8 GiB Disk : 430.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 87.80 MB/s (21.9k) | 148.47 MB/s (2.3k) Write | 88.03 MB/s (22.0k) | 149.25 MB/s (2.3k) Total | 175.83 MB/s (43.9k) | 297.72 MB/s (4.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 175.95 MB/s (343) | 194.49 MB/s (189) Write | 185.30 MB/s (361) | 207.44 MB/s (202) Total | 361.26 MB/s (704) | 401.94 MB/s (391) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3728 Multi Core | 11331 Full Test | https://browser.geekbench.com/v4/cpu/16419165 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 795 Multi Core | 2802 Full Test | https://browser.geekbench.com/v5/cpu/11127408blog | exploring visually |
Ubuntu VM on my desktop at home, often used for dev work -
Same machine, but with NVMe boot Drive. Better disk speeds, shittier GB score
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 459.79 MB/s (114.9k) | 919.40 MB/s (14.3k) Write | 461.01 MB/s (115.2k) | 924.24 MB/s (14.4k) Total | 920.81 MB/s (230.2k) | 1.84 GB/s (28.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.04 GB/s (2.0k) | 1.08 GB/s (1.0k) Write | 1.09 GB/s (2.1k) | 1.16 GB/s (1.1k) Total | 2.14 GB/s (4.1k) | 2.25 GB/s (2.1k) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3773 Multi Core | 11676 Full Test | https://browser.geekbench.com/v4/cpu/16418717 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 730 Multi Core | 1808 Full Test | https://browser.geekbench.com/v5/cpu/11119651blog | exploring visually |
Dedipath
openvz
phoenix
no IPv6
but comes with 2 x IPv4
BF deal $2.27 /mth
My Seattle ryzen has ipv6
Is it not available in phoenix?
@cybertech where is the Bench for your Ryzen?
