Beware, the disk fio bench is done under the current working directory. If your system has mixed NVME/SATA SSD/HDD, make sure to do more disk benches under the corresponding directories.
edit: this YABS result was posted on almost "real time" basis- 4 or 5 lines posted at a time as the results were displayed on the terminal. Copy/pasta errors to be excused.
hazi.ro NAT LXC, 1GB RAM, 160GB HDD; offer link
IPv6 address is invalid; IPv4 has only outbound; benchmark taken via VNC and exported through transfer.sh
@yoursunny said: hazi.ro NAT LXC, 1GB RAM, 160GB HDD; offer link
If you have problem with accessing it through IPv4 NAT then check your configuration of ssh daemon on this VPS (/etc/ssh/sshd_config). Port number there have to be changed from 22 to the same as designated external port and enable "PermitRootLogin yes". It worked for me when I reinstalled from default Centos 7 to Debian 11.
In case anybody got interested in this beast, the Alwyzon Cyber Weekend sale is still ongoing and there is also some stock left for the 35 €/yr promotion of the Virtual Server XS. (The EcoServers are nearly gone thought.)
— Michael
yes i do not see any ipv6 in my panel..
made a sneak preview here:
https://talk.lowendspirit.com/discussion/comment/75938/#Comment_75938
Indeed.. I meant with the NVMe.
Are we there yet?
blog | exploring visually |
no
amazon sent by snail mail.
Ah The anticipation!!
dedipath performing better on debian 10
Webhorizon Cloud Five Solutions
Fri Nov 26 07:11:48 EST 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 2 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : 78.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 636.20 MB/s (159.0k) | 4.42 GB/s (69.0k) Write | 637.88 MB/s (159.4k) | 4.44 GB/s (69.4k) Total | 1.27 GB/s (318.5k) | 8.86 GB/s (138.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.02 GB/s (5.9k) | 4.44 GB/s (4.3k) Write | 3.18 GB/s (6.2k) | 4.73 GB/s (4.6k) Total | 6.20 GB/s (12.1k) | 9.17 GB/s (8.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 249 Mbits/sec | 285 Mbits/sec Online.net | Paris, FR (10G) | 243 Mbits/sec | 286 Mbits/sec WorldStream | The Netherlands (10G) | 288 Mbits/sec | busy WebHorizon | Singapore (1G) | 118 Mbits/sec | 81.7 Mbits/sec Clouvider | NYC, NY, US (10G) | 258 Mbits/sec | 185 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 73.1 Mbits/sec | 247 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 112 Mbits/sec | 142 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 125 Mbits/sec | 111 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed Clouvider | London, UK (10G) | 290 Mbits/sec | 282 Mbits/sec Online.net | Paris, FR (10G) | 295 Mbits/sec | 282 Mbits/sec WorldStream | The Netherlands (10G) | 293 Mbits/sec | busy WebHorizon | Singapore (1G) | 112 Mbits/sec | 207 Mbits/sec Clouvider | NYC, NY, US (10G) | 269 Mbits/sec | 274 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 122 Mbits/sec | 254 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1480 Multi Core | 2789 Full Test | https://browser.geekbench.com/v5/cpu/11232408 Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7088 Multi Core | 11187 Full Test | https://browser.geekbench.com/v4/cpu/16422983@Abdullah @ofit
@vyas which plan is this? GB scores?
GB is not possible to run here.
Hostcram
Fri Nov 26 16:44:51 UTC 2021 Basic System Information: --------------------------------- Processor : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz CPU cores : 1 @ 3500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.0 GiB Swap : 1.5 GiB Disk : 9.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.17 GB/s (294.9k) | 3.44 GB/s (53.7k) Write | 1.18 GB/s (295.7k) | 3.45 GB/s (54.0k) Total | 2.36 GB/s (590.7k) | 6.89 GB/s (107.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.47 GB/s (6.7k) | 1.39 GB/s (1.3k) Write | 3.65 GB/s (7.1k) | 1.48 GB/s (1.4k) Total | 7.13 GB/s (13.9k) | 2.88 GB/s (2.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 862 Mbits/sec | 171 Mbits/sec Online.net | Paris, FR (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 914 Mbits/sec | 504 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7549 Multi Core | 7216 Full Test | https://browser.geekbench.com/v4/cpu/16423246 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1652 Multi Core | 1724 Full Test | https://browser.geekbench.com/v5/cpu/11239627blog | exploring visually |
OMG which provider?
hetzner-k3s - The easiest and fastest way to create production-ready Kubernetes clusters on Hetzner Cloud
which server?
BF is probably not the best day to test this, anyway here we go...
Netcup RS Black Storm
LiteServer BF 2G NVMe:
@Abdullah 2GB RAM has 1vCPU or 2vCPU?
YABS for @ShockHosting Free 3 months Dedicated Server!
I should have bought one ...
@alwyzon Virtual Server XS
Website: thomassen.sh
can't YABS, github died entirely sad.
Thanks for sharing
— Michael
Hetzner dedi 4x NVME RAID 0 (I like to live on the edge!) (JK, I do backups every 6 hours)
Black Friday flash sale: Hostodo $199/year dedicated server
That’s very good for hdd
WebHorizon 256MB NAT in Chile 🇨🇱:
