Lightweight server monitoring
iandkiandk Hosting ProviderOG
Hi,
Can anyone recommend a simple self hosted solution for uptime monitoring of servers, services and websites?
So ICMP, port check and HTTP status code.
I tried Statping but unfortunately it seems pretty buggy, is anyone here using Statping as well?
Before I continue messing around with it I want to see if there are better alternatives.
I read about PHPServerMonitor, does anyone have experiences with it?
Or can recommend a better alternative?
Thanks!
    Thanked by (1)bdl
  • Naemon
    Thanked by (1)FlamingSpaceJunk
  • iandk said: I read about PHPServerMonitor, does anyone have experiences with it?
    Yeah it's absolutely solid. I'm running that on a NAT box at Wishosting and it's been super reliable for many years. I didn't even realize I was running it until I read this thread.
    What’s the Ressource usage like?
    Thought it’s using a MySQL DB, does that even run on such small boxes?
    Think I’ll just try to get Statping to work.
    I have a few dozen or so services configured. It runs on 256 MB of RAM and 1 vCPU. Load is negligible.
  • IndoVirtueIndoVirtue Hosting ProviderOG
    Selling US/Asia/Singapore KVM/OpenVZ SSD VPS and Dedicated Server at IndoVirtue.
  • iandk said: I tried Statping but unfortunately it seems pretty buggy, is anyone here using Statping as well?
    Yes, have been running it for months. Default settings. RAM usage is less than 3 MB, that's including web server and SQLite DB.
    I've only used HTTPS functionality, and it works fine for several websites. There was a minor glitch in admin UI, but it got fixed.
  • Used PHPServerMonitor many years ago. It worked fine but was a bit buggy. I found the cron didn't work half the time and statuses weren't actually being checked. Seems like it worked on and off, possibly a bug that got fixed though.
  • I’ve heard good things about Cockpit. I have yet to try it though, since I’m lazy and just use NodeQuery instead.
    edited December 2019
    Oh I thought they are dead?
    Haven't heard of NodeQuery for a while.
  • gbshousegbshouse OGServices Provider
    TICK stack is pretty nice, we use it internally
    Auth DNS and anycast provider Rage4
