What do you guys like for your /etc/resolv.conf?
2»
  • edited December 2021
    I'm using these
    9.9.9.10
    149.112.112.10
    2620:fe::10
    2620:fe::fe:10
    The lowest response time from my location.
    Thanked by (1)uptime
  • @vyas said:
    4.4.4.4 if you are MjJ
    @dahartigan
    8.8.8.8 is double death :bleep_bloop:
    Thanked by (1)vyas
    8.8.8.8
    1.1.1.1
  • Using the resolvers of a Swedish VPN-provider. (They have both v4&v6)
    46.227.67.134
    192.165.9.158
  • Using these the most
    1.1.1.1
    8.8.8.8
  • On my servers I usually rely on a combo of Cloudflare (1.1.1.1) + Google (8.8.8.8). I usually add Cloudflare IPv6 as the third option.
    For personal usage I rely on AdGuard Home and then Quad9/Cloudflare (in that order) as fallback.
    I should probably start using some IPv6 addresses in my resolv.conf as well, but seeing as providers randomly have issues with IPv6 connectivity, it'd probably be picked as a third option.
    Thanked by (1)vyas
    Home stuff is 1.1.1.1 over DoH via pihole
    ...VPS not too fussed...whatever is the default.
  • Question: what's the point of DoH besides circumventing firewall restrictions, especially if one already have a VPN?
  • edited January 2022
    I prefer a local unbound/powerdns, it adds a few ms fore sure but don't wanna use google/cloudflare/others
  • RadiRadi Hosting ProviderOG
    edited January 2022
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    Just because those are the first IPs that come up in my head when I am asked to enter DNS resolvers. I am trying to get myself to remember 1.1.1.1 as well.
    If IPv6 is present on server:
    nameserver 2001:4860:4860::8888
    nameserver 2001:4860:4860::8844
  • TemasekTechTemasekTech Hosting Provider
    we using
    8.8.8.8
    208.67.222.222
    TemasekTech - AS139859 and AS209187
    Building Cloud Technology with Global Network
    Official Website - https://www.TemasekTech.com
  • mikhomikho AdministratorOG
    So… what resolvers are your local dns servers using?
    Unbound can (and is generally used to) work as a recursive DNS server, not just forwarding. Probably that?
  • @dahartigan said:
    I use 1.1.1.1 and 8.8.8.8 plus Google's ipv6 resolver.
    No other fancy stuff he he
    Same on my side only the other way around first google then 1.1.1.1
  • xTomxTom Hosting Provider
    I use ours:
    185.222.222.222
    45.11.45.11
    2a09::
    2a11::
    █ xTom - https://xtom.com/ - Global Dedicated Servers, Colocation and IP Transit. | Subscribe our newsletter
    █ V.PS - https://v.ps/ - Global VPS Hosting. | Mastodon @[email protected] | @[email protected]
  • carlin0carlin0 Retired
    I use 1.1.1.1 and 8.8.8.8 in this exact order
    F. Battiato ---
