He doubled the resources so did I, that was the deal so I guess yes.
But keep in mind, its fair share, the Port is limited to 100Mbit for reasons, the highest port speed we have enabled yet for microLXC however I/O and CPU is shared since its a Virtual Machine.
Just the theoretical numbers you could burst into for some time.
Nice limit you havw for disk iops and network bandwidth..
NaranjaTech / @gleert KVM-NVME-4GB-LET
Lovely I/O.
The CPU single core is actually lower than a
AMD EPYC 7452 32-Core Processor
which scored: 995
Blazing fast new CPU
wtfffffffff any details on the hardware
surely the new hetzner AX100... I'd be interested in additional hardware info as well... like mobo, memory sticks, nvme types etc.
central.so
OVH Singapore
ExtraVM Los Angeles
microLXC Large (Norway), 1 Core (75%), 1GB, 25GB SSD
microLXC Large Dronten, 1 Core (75%), 1GB, 10GB SSD
this is free? wow
Indeed booth are capped at 100, should be enough.
Traffic s counted but the Traffic limit is not really enforced yet.
Hosthatch JP, seems to be 1Gbps port.(Manually iperf3 with 20 threads can reach 2.48Gbps)
Noice performance VPS from HostHatch..
Nexus Bytes Melbourne
Here's for Singapore...
Maybe more ppl running BM or ... @seriesn has different dicks disks config in SG
Mon 17 Jan 2022 10:04:53 PM EST Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 2 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 29.5 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 263.01 MB/s (65.7k) | 2.69 GB/s (42.0k) Write | 263.70 MB/s (65.9k) | 2.70 GB/s (42.2k) Total | 526.72 MB/s (131.6k) | 5.39 GB/s (84.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.98 GB/s (7.7k) | 3.77 GB/s (3.6k) Write | 4.19 GB/s (8.1k) | 4.02 GB/s (3.9k) Total | 8.17 GB/s (15.9k) | 7.79 GB/s (7.6k) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5496 Multi Core | 9330GB5 in similar range as what @corbpie posted.
blog | exploring visually |
what did you pay after discount, prior to reimbursement?
My kind of size.. 38
VM specialists hybrid wolves in UK
the disk io is the NVMe part... now you'd wonder, how it would look for the large storage...
dunno what kind of magic trickery @Mr_Tom did there underneath... zfs with an nvme caching device maybe? awesome sh*t!!
@Falzo now you're making me regret not picking it up
Team push-ups!
go get one... it's again available https://console.vmspecialist.com/order/main/packages/order/?group_id=2
servarica lion ssd
lite server storage
HT-hosting Christmas deal
there seems to be some bugs with this one , i may update later
OVH
Central.so Budget KVM-Silver SG
ZappieHost 4GB Chile KVM @Zappie
Excited to see the server go live for your project(s)
Smolest Dedi (Thinclient) 4GB Dedi by @natvps_uk
