low priced HDD models
edited February 2022 in Requests
Hello everyone , I'm looking for some cheap HDDs at least 12 TB per HDD sata is preferable but sas is also good. I want to make them a storage node as big as possible , so I'm waiting for some model recommendations.
for working on p440ar / P420 raid controller
I'm generally interested in refurbished ones, I'm waiting for some model recommendations.
Regards ,
Calin
    Have a look at the datahoarder subreddit...they're constantly looking at this question
    @cociu should have many
    Thanked by (1)bdl
    They have warnings.
    No hostname available. affbrr
  • Stay away from refurbs jeez.
    But why? It's gonna be only some customer data on it
    Nothing of personal value
  • Go quickly grab some from cociu's dc. You might as well have that customer database copy you wanted.
    Thanked by (1)bdl
  • WD shucks for SATA: https://shucks.top/
    Used SAS, lower capacity but cheaper per TB: https://bitdeals.tech/
    Thanked by (1)retrotech
  • The new Toshiba "enterprise capacity" drives are incredibly cheap and (i bought a couple) they work very well
    If you're gonna RAID it anyway then it might not be a bad play?
    If you shuck, don't forget to scan for errors before removing the case!
    Thanked by (1)seanho
    If you buy refurbs, buy them in batches and expect a 30-60% failure rate, so buy 2x more than you need immediately, and be prepared for failures out of the gate-1 yr after purchase. It's a gamble for sure but if you have solid backups elsewhere and are OK with downtime during restoration, it's a reasonable option to keep the prices cheap.
