[ IncogNET LLC ] - Privacy By Design We believe that privacy and freedom of expression are two very important things, so we offer solutions to accessing and publishing content safely.
[ USA: Liberty Lake, WA | Kansas City, MO | Allentown, PA ] [EU: Naaldwijk, NL ] [ CL Shared | KVM VPS | VPN | Dedicated Servers | Domain Names ]
@chimichurri said: @Abdullah: Thank you for testing the same machine with different operating systems! m_ _m
I'm assuming you didn't tweak any of these and were just running YABS on a fresh install?
Any thoughts on why Ubuntu might be having ~30% lower IOPS than Alma or Rocky with block sizes other than 4k? In my amateur eyes, one would expect Linux 5 to perform better than Linux 4, unless it's something else than the kernel at fault here..?
yes all were fresh installed, OS images provided by Hetzner.
The Ubuntu 20.04 is HWE version. no idea about the IOPS difference, maybe something related to caching or file system default block size differs (?)
@chimichurri said: Azure E2d v5 with standard HDD, Japan East (OS: Ubuntu 20)
I thought this thread was for low end providers; not Azure!
Well I've been spinning up c5a.8xlarge (32 cores, 64 GB) instances for a project of mine, would be interesting to see a bench from there I'll see if I can spin up one and post here.
yes, please.
if you go through this topic you'll find quite some large servers and also different cloud instances from aws/azure/hetzner that have been yabsed
@stevewatson301 said: AWS Lightsail 1GB plan. (Disk is quite disappointing and CPU is okayish, perhaps only to expected of "enterprise" oriented products.)
yeah, that's a very good example why pure "high numbers" are totally overrated. enterprise really does have different priorities...
I don't know, where your lightsail is sitting, or for how long you have it, however I benched mine:
isn't it scary how close the numbers are to yours? it's perfectly balanced - no matter where or when you spin it up, you get the same ressources or level of performance.
sure, if you need more, you need get something bigger - that's how upsell works and Jeff wants your money. but it's gonna be reliable like nothing else..
Playing around with the instance a bit, I discovered it’s just a t2 instance with disk and bandwidth thrown in the price, unlike normal EC2 instances. So yeah, as disappointing it is from a LE* perspective, it is what you’d expect.
Lemme see if I can get the c5a.8xlarge bench, although I’m scared to run the bandwidth test because of the damn pricey egress.
TerraHost Nigeria. Going to announce some V6 and use as a African continent website mirror.
Noice.
blog | exploring visually |
The issue is the routing in Africa, check Ripe Atlas, otherwise I would have grabbed one.
You better off getting a Machine close to Africa.
https://webhorizon.net
@Mason
sharing some user suggestions from other forum
add +1 from me aswell for these enhancements.
4 vCPU, 8 GB RAM, 200 GB SSD originally from HostSolutions - Now with TerraHost that honored the price of 6.5 euros per month.
Website: thomassen.sh
Virmach 1.5 GB Ryzen Special (Seattle) - $16.46
Hostcram
5950X
LXC
rebench after upgrade to kernal 5.13
(this will be up for transfer soon, PM me if you already want it)
Guys its very easy to do that by yourself.. it only takes 5 min.
Add this code after echo -e "Disk : $TOTAL_DISK"
And you will get this :
From lowhosting free offer-
1 core 1gb ram
Raspberry Pi 4, 4GB, from @DataIdeas.
Poor microSD, really.
.#Lowendazure
yes, please.
@bruh21 said
Inception Hosting?
Advinservers.com New Year Flash Sale - KVM Ryzen 4GB
frantec buyvm luxembourg slice 1024
what do you think about the speed results?
Servarica
well, the cpu is a bit weak compared to other ryzen hosts, but his servers are obviously full to capacity so it's to be expected
Fresh KS-1 from the new "Eco" merge..
Oracle Free Tier:
BillingServ - Easy, simple, and hassle-free online invoicing solution. Contact us today.
BaseServ Certified to ISO/IEC 27001:2013
this is in Frankfurt and got some uptime:
Skip iperf3 test.
curl -sL yabs.sh | bash -s -- -i
( test it on other vps before trying )ServerStatus , slackvpn <-- openVPN auto install script for Slackware 15
