Micro domains and domain hack
Hi
What is you go to platform/site for searching for Micro domains and domain hack?
I'm looking for something just for "internal use" and nothing fancy... Just a short domain/hack to allocate names to servers and to use in develop/tests.
Thanks
  • You can use any domain you like, just add that do you hosts file or use at your own router DNS.
  • TheDPTheDP OGSenpai
    What are "Micro domains"?
    like a.com or a.a or something like this problably
    Ok the first one makes sense but not the latter :smiley:
  • edited March 2022
    If I understand well what he expects, he wants the shortest local domain possible, so instead of ".local" or ".localdomain", he can just set ".a".
    if "internal use" == local network
  • I've used https://domai.nr/ for this in the past.
    Thanked by (1)Ironia
  • Hi
    Micro/short domains. This domain will be used to give names to servers, develop and testing and it must/can be any public TLD - internal was not the best word.
  • Unfortunately my source for these is long gone, but you can see what it looked like here:
    https://web.archive.org/web/20141002195135/http://geek.name/
    @nfn said:
    Hi
    Well, the short ones are expensive and are mostly taken.
    For development/test, I believe there are cheaper options like .cyou, .sbs, .xyz, .cfd etc.
    edited March 2022
    Yeah I know the person who owns/developed that.
  • I run Pi-Hole at home and with the local DNS built into Pi-Hole I use *.svp for all my local machines, and *.ts for servers connected through tailscale.
  • Well, the quickest solution is to modify your hosts file and direct anything to anything... if you want a quick hack that would work with any domain (short or long).
  • If its only for testing, www.freenom.com have a bunch of free TLD's (.tk/.ml/.ga/.cf/.gq).
    I would not run any production on them, but they work great for testing, I have a few of my own.
