Webrimium LLC - NAT VPS IPv6
I ordered server at Webrimium.
Can't connect to it.
Any of 4 IPv6's at VPS Management menu send no answer to ping or ssh (I have server with IPv6 where ping6 works).
Support answered only that my server has IPv6 and no IPv4.
And doesn't answer any questions for 2 weeks.
Did someone buying the same? How did you connect to server?
Thanks for help.
If you got an Nat vps, it should come with a IPv4 port range with a custom SSH port. Check your activation email for details.
If you're using the correct ping for IPv6 with -6 and it doesn't respond, the VPS may not be online or working. If support doesn't reply. Get a refund from your payment processor.
Do you have vnc/console access? Did you configure ipv6 in your vm?
In VPS management menu I have no VNC.
IPs - for changing IP, 4pcs IPv6 , 1pcs IPv4 - trying to change it. After changing IPs nor connection nor ping.
SSH by Java - gaved error "bad sertificate" and closes 3 days ago. Today it start to work.
But after showing field with user@IP it's just closing with no password request.
Can't find any other connection in menu.
No port on IPv4. I used some servers on mrvm and understading it.
On VPS management - server online
