IRC / Discord bridge?
Anyone have any experience with this or recommendations?
Essentially, I'd like to bridge an IRC channel and a Discord channel. We're late to the game and although Discord isn't privacy friendly, I can see the appeal and would like to bridge both methods of communication.
I see some pre-made tools for this, any recommended ones? Anything to consider that I may overlook as someone not really versed in Discord?
[ IncogNET LLC ] - Since 2020
I've not used it but check this out.
https://github.com/reactiflux/discord-irc
In the past I used a fork of discord-irc which did let you use webhooks instead of only a bot account. Although both projects seem unmaintained now...
I'd suggest taking a look at matterbridge instead. It'll do for IRC<->Discord, and other platforms.
You can try bitlbee with https://github.com/sm00th/bitlbee-discord/
However i'm not sue if the discord tos allow third party software clients.
★ MyRoot.PW ★ Dedicated Servers ★ LIR-Services ★ | ★ SiteTide Web-Hosting ★
★ MrVM ★ Virtual Servers ★ | ★ Blesta.Store ★ Blesta licenses and Add-ons at amazing Prices ★
I've seen a lot of people using matterbridge for this.
Thanks! That seems to have done the trick for IRC, Telegram and Discord. Will add XMPP and possibly Matrix, later.
