RamNode | OpenVZ VPS $12/yr LES Sale
2»
    @nessa said:
    Hi all, thank you for your patience. I've added AlmaLinux 9 and Debian 11. Ubuntu 22 is going to be a little bit of a challenge but right now you can install 20 and dist upgrade to 22.
    thanks got one 2GB!
    Thanked by (1)nessa
  • vyasvyas OGSenpai
    @nessa said:
    We have Ubuntu 22 now :)
    May the jellyfish be with you.
    jellyfish
    Thanked by (3)nessa ehab Janevski
    blog | exploring visually |
  • Guys, i never used OVZ before, can you answer me:
    lxc or systemd/machinectl containers will work on OpenVZ?
    They both container itself, and seems that lxc can't work on OpenVZ because of lxbr* network interface can't be created, but what about machinectl (i know its not popular but may be someone have experience with it)?
  • nessanessa Hosting Provider
    If you're talking about doing some sort of nested containerization, no, that won't work on OpenVZ. DM me and I'll find you something!
    RamNode: High Performance Cloud VPS
    NYC - LA - ATL - SEA - NL - DDoS Protection
  • I have some problems with firewall. I use a script to automate the installation of the rules and in the end i have a VPS non reachable. So digging on the net i got this:
    https://techsch.com/tutorials/resolve-iptables-no-chain-target-match-name
    So is it correct to think that is there an uncompiled module into the kernel? Specifically CONFIG_NETFILTER
    Or do I need to activate it in some way?
  • JabJab
    edited September 2022
    This is OpenVZ thing - kernel is 'shared' across node server and VPS-es, you can't just add something locally.
    So if some modules are not installed you simply can't use them. Most of the times you ask your provider (ticket! ;)) if they can install something on the node. Most of the times they say yes, sometimes they say no.
    I would suggest checking that automated script you using and check what modules are missing @kokkez so you won't open 3 tickets for "Hey, I neeed <x>" - then it fails later at y, so you go "Hey, I need <y> also", then it fails at z and you go 3rd ticket "It's me again, I need <z>!" and provider is already mad on you - a lot of manual work for 12$ VPS per year.
    Thanked by (2)nessa kokkez
    Please open a ticket with us, our staff should be able to help with this.
    Thanked by (1)kokkez
  • This is the same reason why on OVZ you cannot use nftables
    F. Battiato ---
  • @kokkez said: uncompiled module into the kernel
    I had iptables_nat module missing into kernel for running vpn, and simple ticket with response time of 2 min resolved my issue.
    same prob, same great response time. perhaps it should be standard on lowend deal packages to save csr time though, lol <3
    I ain’t reading all that, but I’m happy for you though. Or sorry that happened.
    tried a few templates and they have apache2 installed by default. is this normal?
    I kept most of the openvz templates as-is, some of them do have Apache installed by default. I was considering removing it from the spec and rebuilding :/
  • What's your policy on torrent and VPN?
  • edited September 2022
    I had to cancel one of the VPS because the templates are not clean, and having issues installing basic control panels. I have tried all the templates, but all have problems of some sort. I don't know if it's the templates or it's OpenVZ. Unfortunately, this is something I can't use for web projects. I do have one for a VPN. Just my two cents.
    [email protected] | www.ivlad.net
    same experience here. managed to get debian 11 partially working by uninstalling apache2.
    we are a US based host. just don't get us in trouble :)
  • Would be very helpful if there was an offer for like 6$ too. Thanks.
  • good to see now there's 12$, it used to be 15$
  • @nessa Do it support rDNS modification?
  • Sadly my budget is $8
    To me has worked via ticket, and very quickly, because via SolusVM do not work
