Would you consider these packages?
All on Ryzen 5 3500.
NVMe Disks
GB5 of 1 Core is approx 1000+
All on 1 Gbps unmetered line
Edit: The location is Warsaw Poland
Format is 1C (1 Core) / 2GB (RAM) / 50GB (NVMe Disk)/€5.05 (price monthly)
Which package would you choose?
- VPS 1C/2G/50GB/ €5.0529 votes
- Yes20.69%
- No79.31%
- VPS 2C/4G/100GB/€7.7229 votes
- Yes20.69%
- No79.31%
- VPS 3C/8G/200GB/€13.0829 votes
- Yes10.34%
- No89.66%
- VPS 4C/16G/400GB/€23.7929 votes
- Yes6.90%
- No93.10%
Contact me at: +1 (509) 606-3569 or rafal@crunchbits.com
Prices seem a bit expensive for the LowEnd market
The bigger packages are priced adequately, but the smaller ones are not too much. These are meant for people who actually use their servers, and not just idle.
I shall consider it if you pay me instead.
Aye, pay us to test it.
Hetzner is cheaper then you, see no reason to buy them.
Except, this is a rare location, maybe.
Depends, what network? Disk redundancy?
Hetzner is not really cheaper when you consider the disk space.
Also location is Warsaw
With 1Gbps unmetered, I would say that is an ok price.
I assume 1 IP4 and a bunch of IPv6 is included?
1 v4, and sadly no v6 for now, as BGP sessions cost, and basically I'd have to sell something like 80 packages for a BGP session to be covered
In that case the price is totally irrelevant, I would never pay for something without IPv6. To be honest, I would not use it even if it was free.
Could someone please explain what this means? Haven't seen this phrasing before
Geekbench 5 score of 1 core is approximately 1000 because of virtualization
How tf did @skorupion get their provider tag? Did you already set up an incorporated business?
What dc are they?
🌐 Blesta.club - Blesta Modules, Plugins, Gateways and more
💬 Join our community today and start your journey!
Yep.
So, are these dedicated cores? If not, they are more than "a bit" on the high side. e.g server-factory is roughly €8 per 1 core / 2 threads.
Nope sadly not
Physically strong people don't use BGP.
Give each customer a shovel and a spool of fiber.
They dig a tunnel toward your house and plug into your router directly.
No hostname left!
This is exactly what us, real men do.. pffft imagine BGP
Poland locations aren't cheap, actually even higher than german ones. But if you check the offers from webhorizon, you could do this at an affordable pricepoint too.
Are you trying to resell mevspace?
yep (we all gotta start somewhere)
Good luck 👍
Government says no.
I like VPS 1C
