Is this code safe to run?
bikegremlin
ModeratorOGContent Writer
Being a noob when it comes to these things, I suppose it doesn't hurt to ask (and that it's OK to be cautious and skeptical).
Are these below-listed two pieces of code safe to run on a WordPress website?
It's a code made by buymeacoffee platform (similar to Patreon - my review).
Floating widget code:
<script data-name="BMC-Widget" data-cfasync="false" src="https://cdnjs.buymeacoffee.com/1.0.0/widget.prod.min.js" data-id="reljas-id" data-description="Support me on Buy me a coffee!" data-message="" data-color="#FF813F" data-position="Right" data-x_margin="18" data-y_margin="18"></script>
This code returns the following error when clicked upon, shown on the frontent, with a browser console tool (F12):
This other code is for a (nicely designed) support button - and it doesn't return any "errors" in the console:
<script type="text/javascript" src="https://cdnjs.buymeacoffee.com/1.0.0/button.prod.min.js" data-name="bmc-button" data-slug="reljas-id" data-color="#FFDD00" data-emoji="🍺" data-font="Cookie" data-text="Buy me a beer" data-outline-color="#000000" data-font-color="#000000" data-coffee-color="#ffffff" ></script>
I've not used it, but is there a reason you don't just want to use their plugin?
https://www.buymeacoffee.com/wordpress
To put it briefly: the plugin sucks.
PHP errors - apparently not PHP 8.1 compatible.
Plus, it would be yet-another-plugin, which is a very bad policy for running WordPress sites in my opinion and experience.
Fair enough! Some of the Google Pay errors suggested it might not be liking the framing and I naively hoped their plugin would do it properly.
All the 404's from Stripe suggest their widget is pretty broken too :-(
