for ipv6 rdns via control panel also might consider a BuyVM slice in LU (1 GB for 0$3.50/m almost within budget)
I think @freerangecloud also supports ipv6 rdns via control panel - they have a new node in Norway, and might have a deal in your price range if you check with them
I suggest you keep an eye on Netcup (yes DE, but you mentioned you're open to DE too). If you can snag one of their VPS deals (billed annually at roughly €20/year which works out to <€2/month), you'll have everything you need plus a very generous (unusable?) 40TB of traffic a month. They're remarkably stable for the typical VPS use case.
They were part of the Advent calendar for the Dec 2nd but I think they may make yet another appearance.
Scaleway has this. But yeah ?
https://www.scaleway.com/en/pricing
Maybe ExtraVM, but they seem to be OOS.
IIRC, they don't have RDNS for IPv6, unless things has changed?
I hope that you don't need a fully routable /112, because that's going to be nearly impossible, specially if you want a reliable provider.
In Germany you would have some more options from the usual cheap providers.
Scaleway does afaik, I’m not sure about ExtraVM as I don’t currently have a machine there.
Tagging @MikeA
Pardon my question but why is rDNS important, is it for mail use?
... never try to setup your own MTA. kthx.
Too expensive plans.
True, saw your name mentioned, figured if you had any insight on Rdns
I have an ultravps. Details in PM.
(Avoiding linking to the old place .)
They (Scaleway) do provide /64 IPv6 blocks but rDNS for IPv6 is not supported
First-Root's KVM Power Edition Start has everything you want but is just above your budget: 3.6E/mo (VAT excl.) on a 12-month contract. https://www.first-root.com/server/vps/kvm-power-edition/#fndtn-panel-start
No NVMe though. Or is 'regular' SSD also an option, @thedp?
LOL, Online.net did this (in the past) so I leaped to the wrong conclusion.
Regular SSD is fine too.
I know something will come up from Netcup so might just keep an eye on that
Edit: If choices are limited, I will definitely consider UK and DE, and I know who to go for in the UK
HS4LIFE (+ (* 3 4) (* 5 6))
If you're fine with paying yearly I can do one of our Egg plans for $30 (shoot me a DM for discount code). Norway or Netherlands locations: https://freerangecloud.com/cart.php?a=add&pid=111
We do have IPv6 rDNS support - it's a little clunky as you have to add records one at a time. We can also delegate IPv6 rDNS to your own nameservers
https://freerangecloud.com - VPS, shared hosting, LIR services & more!
if you consider DE or FI, cloud.hetzner.com got what you want.
Not 100% sure its ssd though.
See: https://www.netcup.de/adventskalender/
