Nextcloud - on shared hosting/budget?
I have decided to give Nextcloud a try.
My reasoning was to keep my address book and calendar portable (so I can sync any changes accross several computers and phones), but not rely on Google, Apple or other huge corporation.
For files and photos I suppose the likes of good old offline storage combined with Hetzner and even Pcloud (and Filen.io) are probably a more reasonable choice - correct me if I'm wrong.
Of course, I wanted to keep the costs low, so I tried an installation in a shared hosting environment (well, technically it's under a reseller hosting account, but the principle and access rights are the same).
So far so good.
A few error logs, some warnings, but it does work. LOL.
The details (with a list of warnings and errors I came across):
https://io.bikegremlin.com/38385/nextcloud-selfhosted-install-on-shared-hosting/
Corrections, ideas and tips are more than welcome. :)
Thanked by (2)angstrom Ympker
  • edited October 19
    I've been running a couple of Nextcloud installations for a number of years now, but I run them on VPSes
    As your report suggests, it can be tricky to run Nextcloud on shared hosting, but this also depends on how much "freedom" one's shared hosting account gives one. Your shared hosting or reseller account seems good in this respect
    A couple of times in the past, I tried to install Nextcloud on a shared hosting account, but I felt frustrated by the restrictions that a typical shared hosting account typically imposes, so I gave up. Nextcloud has become complex/intricate enough that I simply find it more straightforward to install and to maintain on a VPS
    I'm familiar with virtually all of the errors/warnings that you mention. :) I recall that earlier in the past, I had the goal of eliminating every error/warning, but at some point, I gave up on this and focused simply on eliminating the major/serious errors/warnings :)
    Hetzner's managed Nextcloud looks like a good option in terms of both money and time:
    https://www.hetzner.com/storage/storage-share/
    One of the reasons for posting here was to hear if there are wiser and perhaps simpler alternatives that are still good.
    Having said that, so far, Nextcloud is doing what I need it to:
    I'm using other services for file and picture storage/offload (Hetzner storage box, Filen.io and Pcloud), and for note taking and syncing (Obsidian).
    This! :)
    Over the years, despite my perfectionism (and mild OCD - which are both flaws despite people using them to humblebrag), I have learned to just leave stuff imperfect when that is the more reasonable thing to do.
    Thanked by (1)angstrom
    edited October 19
    Currently (and for many years), I run Nextcloud on a small slice/slab ( @Francisco ) and the cheapest Online/Scaleway dedicated server. I use them as backup repositories rather than anything 'fancy', so just ignore the irrelevant warnings. ;-)
    I have run it before in a shared hosting environment on one of my VPSes but having full control of the setup helps a lot (especially for command line commands).
    I wouldn't trust Hetzner with ANY of my data, given how much they harbour hackers, crackers, port scanners etc. They just don't give a crap about what originates from their infrastructure.
    How about a Oneprovider 1TB HDD dedi?
    Thanked by (2)bikegremlin angstrom
    Nextcloud is quite nice, if properly maintained and configured and tuned. I'm running a few "managed" installations for clients. This will in the near future also turn into a public service.
    Already got a brand name selected, just waiting for the logo to be finished and getting the design done shortly after.
    Regarding running on shared hosting: This can be done and i have some scripts that are running on my shared hosting platforms from sitetide.com . The initial install is no problem, auto-updates,... can be a bit of a nuisance. So once the new cloud storage service launches, i'll likely stop including the nextcloud installer/updater on shared hosting.
    :smile:
    β˜… MyRoot.PW β˜… Dedicated Servers β˜… LIR-Services β˜… | β˜… SiteTide Web-Hosting β˜…
    β˜… MrVM β˜… Virtual Servers β˜… | β˜… Blesta.Store β˜… Blesta licenses and Add-ons at amazing Prices β˜…
    @AlwaysSkint and @SGraf - it is fair to note that the reseller/shared hosting providers I use offer SSH, and that is very helpful at times (not just for Nextcloud).
    Without SSH, I am not sure how my install would have fared.
    Thanked by (1)AlwaysSkint
    edited October 19
    The normal/shared hosting plans on SiteTide have auto-installers. Where required users may request a cron job (via ticket).
    For The Cloud Hosting Plans, you get ssh access, plus Cron Job setup via the Web-UI.
    For the upcoming product line of managed cloud storage products, the aim is a quite different ofc. So there you get cloud storage as a product without any installation/maintainance required. Just ready to use.
    edited October 19
    The normal/shared hosting plans on SiteTide have auto-installers. Where required its also possible to get a cron job (via ticket). For The Cloud Hosting Plans, you get ssh access, plus Cron Job setup via the Web-UI.
    For context: my reply was related to the option of one of installing Nextcloud on their own, in a shared hosting environment (in general).
    If a provider offers Softaculous with shared hosting plans, one could also try the Softaculous' Nextcloud auto-installer (picking the "Custom" install option even lets you set a data directory outside of public_html, which is nice) - but I haven't gone on to finish and install using this automated approach, wanted to do it "manually".
    In the past, I considered Hetzner's managed Nextcloud a couple of times, but in the end, I decided to manage my own installations. That said, Hetzner's prices seem good for what you get
    Around a month ago, mainly because I was curious, I signed up for a free 2GB Nextcloud account at The Good Cloud ( https://thegood.cloud/ ), who are an "official preferred partner" of Nextcloud. One signs up for this free account via the page https://nextcloud.com/sign-up/#the_good_cloud at the Nextcloud site. My impression after a month is very positive: the synchronization is always very quick and I haven't yet noticed any downtime. The Good Cloud claim to be privacy-centric ( https://thegood.cloud/about-us/ ). Not surprisingly, their pricing ( https://buy.thegood.cloud/en/individuals ) is much higher than Hetzner's managed Nextcloud pricing, but I think that I'd be more inclined to choose The Good Cloud over Hetzner for managed Nextcloud
    The Good Cloud website has links that lead to just their "blog page" instead of to where they are expected to.
    That doesn't look very promising.
    To see and compare prices also seems to require a bit more clicking on the site.
    Another thing I dislike.
    I'd agree that the "structure" of the site leaves something to be desired, but I guess that I'm willing to overlook this (unless they're really trying to hide something crucial)
    Since their only product is managed Nextcloud, they seem to be more focused on selling managed Nextcloud to businesses (than on selling to individuals), but I give them a pass on this. :) (In general, businesses are a more promising source of income than individuals are)
    I would add that as far as I can tell, The Good Cloud web site isn't trying to dazzle anyone with a slick design, but I tend to see this as a positive feature :)
  • vyasvyas OGSenpai
    NC install on Myw.pt reseller worked quite well 2020-2023 for me. Had a nice 50-55 GB (don't remember exact)…
    DE, so Hetzner I think.
    once my icloud subscription runs out of prepaid credit, I might take a look at NC again… though Koofr presents a rock solid case.
  • there are also some good free nextcloud instances to use like disroot.org or thegood.cloud which is more than enough for caldav.
    here are more free offers
    https://help.nextcloud.com/c/hosting/14
