how long did you wait? what are the VPS specifications?
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA x2, USA x5, FR x3, AU, PL, NL, JP, BR, ZA FREE tokens on sign up, try before you buy. | Static Hosting Free for life: https://tierhive.com/static-hosting/
@rvldev said: I waited for an afternoon.. and about an hour next several times.
The specs are:
CPU: 2 cores
RAM: 1 GB
Disk: 20 GB
Bought it from CloudCone.
'lscpu' output? if you somehow ended up with a qemu cpu badly configured for some reason (like you self installed via iso or something) you could have emulated instruction sets which means it will be so slow it never completes.
Just a guess.
Ok this time I watched it closely in top, and geekbench disappeared about half an hour. But my ssh session still shows the same. So I guess my ssh client somehow froze after not receiving new buffer. Then I made it pipe to a file and I finally got the result.
The specs are:
CPU: 2 cores
RAM: 1 GB
Disk: 20 GB
check with top/htop while it is running, if you can see activity on the cpu?
The specs are:
CPU: 2 cores
RAM: 1 GB
Disk: 20 GB
Just a guess.
you need swap.
Maybe.
Hmm yes I can see geekbench running in there with 200% CPU.
That could definitely be the case. But it says KVM so probably not that.
Ok I will try that, thanks.
Btw if I disable Geekbench 6 in the flags it can finish the test.
GB6 needs more than 1GB of RAM, I forget how much it needs. Adding swap will let it finish but the score will be garbage.
