Small VPS for Minecraft reverse tunnel (personal use)
Hello,
I am looking for a very small and free VPS (1 vCPU, 512 MB RAM, 5-10 GB disk) for a personal project.
My ISP (Rostelecom) blocks all public tunneling services (ngrok, playit, localtonet). I have a working Minecraft server at home, and I need a VPS only to run a reverse tunnel (SSH or FRP) so my 3-5 friends can connect to it via the VPS.
I will use minimal resources, just for port forwarding (TCP port 25565). I can provide proof of my setup if needed.
Thank you for your consideration.
Flagged for moderation (1)
https://lowendspirit.com/discussion/10743/tierhive-from-0-000135-hr-new-pops-france-and-vint-hill-make-your-own-plan-de-fr-uk-ca-usax2#latest
free 3$ , 0.1$/m
TierHive doesn't work with clients from Russia. I would gladly use their services myself.
Thanks for the information about TierHive. It's a pity that they don't work with Russia. Maybe you know other providers that provide small VPS for similar tasks? I will be grateful for any hints.
Bypass the ISP.
Pull an Ethernet cable to each friend house.
Use ULA addresses.
https://veesp.com/ - not free, but cheap.
What about Tailscale or NetBird, or are they blocked/dont work with russians as well?
Then his buddies would have to install a client and stuff, right? Instead of just connecting to his VPS?
True, but Tailscale for example is free up to 6 users and easy to setup.
