LES - New Feature - "LES Ignore User"
AnthonySmith
AdministratorHosting ProviderOGSenpai
First new feature in a while.
LES Ignore User
This gives you the ability to ignore the discussions and comments by any other user you just can't find common ground with, or that causes you any irritation or distress.
Just click on their name to get to their profile and select ignore user:
Their discussions will now be hidden in the main forum feed for you, to remove the ignore, it's the same process.
Their comments will also be hidden in line, instead you will just see a small indicator so at least if the discussion takes a strange turn from your perspective will have some clue why.
This does not hide quoted posts from the user you ignore in posts other users you dont ignore.
Feels like a bit of a negative start, I suppose, but people have talked about this off and on for years, the logic is simple so it was a good one to start with.
Any bugs, please report them here or PM me or email me.
Notes:
- 1 hard refresh might be needed.
- You won't see a list of ignored users; it's not to be used lightly. Only use it if you really want it.
- You cannot ignore mods or admins.
Posting ITT so everyone gets a chance to test it out.
"It's a hard life- to be a stick insect." - Karl Pilkington
Test
We can all be ignored except for @AnthonySmith
apt mooOk
First up to be ignored @AnthonySmith
/ₛ
huh?
Who said that?
Is that a planned feature?
Huh? Why not?
nope, why would you want it?
"Ignore LESbian" would be better.
