@Frameworks said: @AnthonySmith Can we put the dark mode toggle on the main page instead of inside the profile settings?
LES V2 is coming and that's going to be a thing.
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA x2, USA x5, FR x3, AU, PL, NL, JP, BR, ZA FREE tokens on sign up, try before you buy. | Static Hosting Free for life: https://tierhive.com/static-hosting/
@AnthonySmith said: LES V2 is coming and that's going to be a thing.
Hope the rest of the layout won't change much - Vanilla is very good in this regard.
Naa not much, few tweaks and fixes and the grey theme works now and there is a vBulletin Dark and light theme
some samples.
Edit Profile > Theme > Dark
https://phpbackend.com/
Great! Thank you!
☰ VDS & Storage — Budget AMD EPYC VDS (ref) from $4/m / Big HDD VPS (ref) from $2/TB/mo / EPYC/Gold/Platinum dedis (ref) w/ GPU support
some samples.
Can you disable the lame border thing?
yep.
