Roseline panel, a project migrate all your servers
Rosélune, means rose and moon,
I developed it because I have 20+servers which is hard to control.
With Claude code, I wrote some good styles and powerful functions, complete mcp support, you can check here: https://github.com/Dokoyamo-Lisa/Meridian
Example page: status.losantos.space
  • A panel for proxy and VPN servers: Xray (VLESS/REALITY, VMess, Trojan, Shadowsocks), Hysteria2 and WireGuard, with users' own pages, a live status globe, country rules, a REST API and MCP.
    Whats better than others, non clauded scripts?
    actually the readme is out of date and im lazy to update.
    The UI design was the part that took me the longest, and I also put a great deal of thought into designing the various features. I recall that Claude wrote doc.losantos.space, which covers most of the panel’s functions. The proxy feature is one of the key features, but it is not the only one.
  • natboxionatboxio Provider
    Nice project. MCP support is an interesting touch for a panel. How does it handle the agents on each server: SSH, or a daemon you install? And is there an auth/2FA option on the web UI before people point it at 20+ boxes?
  • It looks really good but vibe coded and untested is not a good combination when it comes to security.
    Yes, cus I don’t know how to enhance security ( I can only focus on design and function
    Thank you )
    Yes, accept passkey, agent talk to main server using websocket/http
  • Been looking through this repo. The scope is wild: Xray, Hysteria2, WireGuard, per-user pages, live globe, country rules, break-in checks, plugins, MCP server, all in one panel. README is also one of the clearer ones I've read.
    A few things would help adoption:
    1. Move the rename note to the top. The "Meridian became Rosélune" line is buried at the bottom. Anyone searching for "Meridian panel" will be confused for a while. Put it right under the title.
    2. Quick start could show expected output. The
      curl | bash
      step is fine, but "Add a server" doesn't say what the agent does on first connect, how long it takes, or what happens if a core fetch fails. A short "what you should see" section would cut support questions.
    3. The feature list is a wall. "What it does" is thorough but hard to skim. Maybe split into "the 80% path" (install, add server, add user) and a collapsed "everything else". Right now break-in checks and plugins compete with basic setup for attention.
    4. Promote the demo. There's a demo/ folder with a read-only demo panel, great idea, but it's only in the file listing. Link it from the top. Letting people click through before installing is probably the biggest adoption win available.
    5. Add a "known limitations" section. Every serious self-hosted tool has sharp edges (kernel WireGuard modules, Postgres vs SQLite tradeoffs, failed updates). Listing them openly reads as maturity.
    Not a knock on the project. Mostly docs and onboarding. The compiler/agent split and signed update flow are solid. Happy to PR the README reorg if useful.
    https://omanwebhosting.com | .om domains, shared & dedicated hosting, VPS | by Technology Solutions Company L.L.C
  • Thank you Claude.
