How Is NordVPN Unblocking Disney+?
https://medium.com/@derek./how-is-nordvpn-unblocking-disney-6c51045dbc30
Interesting way used to catch them, using the Akamai header.
Only thing left from the article would be a portscan proving that a big percentage of the listed hosts are webcams, home routers and other insecure IoT stuff. They use a backconnect to route traffic trough compromised hosts, this is common practice in the VPN industry.
I'm of course biased, but think twice before supporting with your wallet this kind of scum.
  • MikeAMikeA ProviderOG
    edited November 2019
    If what is written in that article is true, isn't this pretty much highly illegal for NordVPN to do?
    I've only used a few commercial VPNs, and only stick with PIA now, and I've never seen any popular commercial VPN do this.
  • FHRFHR ProviderOG
    Depends on how they gain access to the proxies. If the users (who serve as relays) agreed to run the proxies on their computer, it's probably not illegal.
    However, if they use compromised machines.... that's a whole another thing.
  • Yeah, it's mostly illegal and there is a whole industry constructed around the lack of public knowledge about the practice:
    https://medium.com/@xianghangmi/resident-evil-understanding-residential-ip-proxy-as-a-dark-service-dea9010a0e29
    The only "legal" service of this kind would be Hola/Luminati since they kind of ask permission from their users, as far as I am aware.
    This backconnect technique is exactly the same which has been used by carders for decades, but now there are "legal looking" services providing this for geoblocking bypass, bots buying concert tickets and limited edition sneakers, scraping... that kind of stuff.
    Yeah, I'm talking if they end up mostly being compromised IoT devices, that would be really bad since large commercial services would be fueling it.
    The second link I provided shows context on the number of positively identified IoT devices (nearly 50%). You can't just identify every device, but gives a good idea of what is going on.
    Damn. I regularly use a VPN. Is there a way to check if my network is being (ab)used in this way?
    It's pronounced hacker.
    Generally speaking it isn't being abused from your VPN usage, except if you are using Hola, then yes.
    They source those hosts from other places, your VPN provider isn't using you as a host. A different question is if you can trust them.
  • Oh, I get it. I'm an idiot. Still not cool. I use AirVPN. I like their philosophy in general, I certainly hope they're not stooping to this level of assholisness.
  • Very concerning, thanks for the share.
  • Yikes
  • Eyebrow raised
    This should be popcorn material soon.
  • maybe PIA and Ivacy do the same? :s
  • nottynotty OG
    I was confused why they needed the Akamai header thing instead of just going to whatismyipaddress.com or similar.
    Do these VPNs route your traffic via different IPs depending on the traffic destination? If so, even that is a bit shady and unexpected.
    root@notty
  • P0rnhub got Into VPNs With VPNhub
    Just dropping this here.
  • edited November 2019
    THIS is something I am going to read in detail with interest, this could be a huge deal if it gets blown open by the popular media.
    Someone link the Linus Tech Tips forum to here to read about it :)
  • These are actually pretty serious allegations, albeit coming from an unknown Medium author. I'd like to see some kind of independent verification before we jump to conclusions.
    Perhaps someone who has NordVPN can try out the curl command in the article and report back?
    root@notty
    I'm def not renewing PIA after them being acquired recently.
    Gonna try my luck running own VPN
    Take a look in to the NAT world, between me, @mikho and @cam you have the choice of around 16 locations world wide.
    I suppose it depends on what you use them for.
    Not to brag, but I got 14-15 locations on my own ;)
  • ok about 20 then.
    MR.VPN coming soon?
  • AnthonySmith said: Take a look in to the NAT world, between me
    Yeah think I have some of your 256mbs.
    Might post something elaborate in technical section at a later stage, but getting some blog stuff up and running is priority
  • notty said: I was confused why they needed the Akamai header thing instead of just going to whatismyipaddress.com or similar.
    Well, not so shady in itself.
    Imagine I want to connect to a server in The Netherlands for my normal activities, but also want to watch US Netflix. They will provide the NL connection and redirect some Netflix traffic to the US residential backconnect.
    They will always try to route as little traffic as possible through the backconnects because it is slow and expensive, only whatever is needed to pass the geo checks.
    notty said: These are actually pretty serious allegations, albeit coming from an unknown Medium author. I'd like to see some kind of independent verification before we jump to conclusions.
    Of course that would be good (and easy to do) but I have no doubt. There is not any other way to access this kind of residential-restricted services, you can't rent a server anywhere, a real residential connection is needed and you need lots of them because otherwise they would be banned and of course they are slow and unreliable.
    havoc said: Gonna try my luck running own VPN
    Maybe you already know, but maybe try combining this:
    https://talk.lowendspirit.com/discussion/186/inception-hosting-black-friday-servers-from-2-33-p-year-30-discounts
    With this:
    https://github.com/Nyr/openvpn-install
    Lots of people will give assistance here if you need help figuring things out.
  • nottynotty OG
    Amazingly it seems there are patents covering these "methods" for obtaining the IP addresses. Maybe not be quite as bad as IoT botnets, but still extremely dodgy. I'll be thinking twice the next time I download a "free app".
    https://cdn-resprivacy.pressidium.com/wp-content/uploads/2018/08/Luminati-Networks-LTD-vs-UAB-Tesonet.pdf
    Upon information and belief, the above OxyLabs embedded code has been
    integrated in at least the following software applications that may be downloaded by any user
    located anywhere having Internet access: AppAspect Technologies’ “EMI Calculator” and
    “Automatic Call Recorder”; Birrastorming Ideas, S.L’s “IPTV Manager for VL;” CC Soft’s
    “Followers Tool for Instagram;” Glidesoft Technologies’ “Route Finder;” ImaTechInnovations’
    “3D Wallpaper Parallax 2018;” and Softmate a/k/a Toolbarstudio Inc.’s “AppGeyser” and
    “Toolbarstudio.”
    (Edit: this is not NordVPN's patent. It seems Tesonet the defendant is allegedly linked to Nord)
    root@notty
  • Yeah I would just throw a VPN on a LES " @AnthonySmith @mikho " or @cam box. In my testing they have been reliable and they do the job for so little money!
  • notty said: It seems Tesonet the defendant is allegedly linked to Nord
    A classic act done with a shell company.
  • notty said: Do these VPNs route your traffic via different IPs depending on the traffic destination?
    That's not uncommon, particularly with VPNs that advertise unblocking content located in different countries as one of their features. For example, some VPNs let you watch American Netflix, BBC (UK), and ABC iView (Australia), all without having to switch to a different VPN endpoint to change the country. In cases like that they tend to configure their routing tables so that particular IP ranges are routed differently - Traffic destined for Australian services will be routed via Australia, etc.
  • So breaking this down in to super simple terms, if all the IOT things were to universally patch their shit, the VPN providers employing this tactic are dead?
  • Interesting that they figured this out using an Akamai header that it's generally considered best-practice to block access to for security reasons.
    I haven't seen any proof that they are actually using compromised IoT devices. Most likely that they get access via dubious "free" apps that unwitting consumers have installed - see the quote from the legal document I posted above. Still pretty dodgy mind you.
    root@notty
    Ok so a change to that law to build actual accountability in to that practice end to end and their business model fails then?
  • NyrNyr OG
    edited December 2019
    There's also the typical compromised desktop I'd guess, they don't depend on IoT, it's just another source.
    See the second paper which identified specific devices. Apps installed in your printer? In your webcam? Sorry but I seriously doubt it.
  • Nyr said: Apps installed in your printer? In your webcam? Sorry but I seriously doubt it.
    That's not what I meant. Look at the list of apps posted above and you'll see they are mainly android apps (“EMI Calculator”,
    “Automatic Call Recorder”, “IPTV Manager for VL”).
    Nyr said: See the second paper which identified specific devices.
    I assume you mean this paper. I must be missing something here. The paper doesn't mention NordVPN anywhere, so I don't see how it is relevant?
    Hey, maybe they do use IoT botnets, but I'm not seeing any smoking gun evidence here.
    root@notty
  • NyrNyr OG
    notty said: That's not what I meant. Look at the list of apps posted above and you'll see they are mainly android apps (“EMI Calculator”, “Automatic Call Recorder”, “IPTV Manager for VL”).
    Yeah, I'll give you that. Each network will have different recruitment methods and while I'm sure that they do this (everyone in the industry does and if not they directly, the people they pay for recruitment do), there is no evidence about that specifically.
    That said, 4G networks would usually be used for other stuff which is not streaming, since they are more expensive that landline residential bandwidth. They are for example used for Instagram bot accounts because the NAT usually present in mobile networks means that the social networks have much more trouble filtering bots than they would from a residential connection with a single dedicated IP address.
    Sigh. Actually that's a good idea. If the traffic is coming from a residential IP most hosts won't suspect foul play or that it's from a VPN or proxy. The only issue is that there is no user consent. They should have offers that give something back to those that want to host the VPN servers.
