LES Wiki - work in progress.
InceptionHosting
Retired
The LES wiki is going to be very much a work in progress and will take over all 'list posts' in time, I have made it visible for now with a top bar link.
Eventually, when I move talk.lowendspirit.com to lowendspirit.com it may replace the current 'blog' based on grav completely, that is still under consideration though.
Suggestions on content for the wiki are welcome please ![]()
Thanks @AnthonySmith for doing this
@AnthonySmith
FREE Blesta licenses by BuyVM and NexusBytes
FREE Softaculous Premium by BuyVM
@Francisco and @seriesn , please correct If I get it wrong
That sounds Great @AnthonySmith _/_
For Wiki Suggestions, something like Installing Selfhosted Open Source stuff on LowendVPS providers
"how to"s lots of "how to"s
vpn, proxy, dns, torrent, xamp, wp scripts, media server installs, hosting scripts installs, proxmox , ipv6 only proxmox, proxmox ha?.....
Well, I don't think it is the right format to have the actual guides in but it will be great to link to them when they are written
A Self-Hosted Category.
Have you tried turning it off and on again?You're gonna take a mega SEO hit on that if I'm not mistaken. Subdomains are scored separately so basically start from zero
Users can contribute (write) to the wiki as usual?
A 301 Cloudflare Page Rule should take care of passing the Link Juice in sometime
Great job @AnthonySmith
How can we contribute?
nope, at least not directly, I can't afford the time to moderate the spam and dead stuff.
That was what I was hoping, but the place is only a year old I can live with the 'hit'
I guess the only way I can think of right now is to make a wiki contributions category when it gets approval I will take the content and push it into the wiki.
Sounds great
Just some ideas:
Self-Hosting
Backups
DNS
Security Hardening/Tips
https://cyberhost.uk
if anyone has any scripts or configs they use and want to share that would be great, I am not talking about self-made software suites but more like backups scirpts, one liners to do xyz, nginx/mysqld conf's etc etc
Noticed that only Nexusbytes is listed under hosts giving free Blesta, but according to their website BuyVM also does so.
FreeVPS.org - Grab a free VPS! | SOGo Webmail - Powered by Alinto
Thanks, yes, it will take a while and good people like you to help get that info on the site, I am seemingly incapable of keeping all of these things in my head these days
good job I am making a directory eh!
LXD, LXC Idiots Guide complete
Wireguard Idiots Guide complete
VXLAN between LES VPS, NAT VPS, network and port forwarding.. I shall test with InceptionHosting then expand to Cam and MrVm NATs.
docker for idlers: a concies guide (install, configure,use, backup, delete, f*ck up, recover, try to keep it running)
Will I be able to add a definition for male PMS?
It's a common occurrence in low end world.
ā» Amitz day is October 21.
ā» Join Nigh sect by adopting my avatar. Let us spread the joys of the end.
The last flan is taken. š® affbrr
In regards to how-to guides to install generic xx service or program, don't see a need for them here as there are already 1000's of same guides already available with a google search. If anything, more vps specific how-to's such as Anthony already mentioned : "backups scripts, one liners to do xyz, nginx/mysqld conf's etc etc.
One liner to break OpenVZ 7 so bad that it would require a reinstall:
I found this when I'm trying to stop SolusVM from overwriting my config. Apparently this breaks the container and it will never boot again.
One liner to stop SolusVM from messing up the config:
Tested on Gullo's Hosting Canada.
No rm -rf jokes, please.
Have you tried turning it off and on again?@Not_Oles already lost his hair on this, lets see who next.
i would settle in installing k3s master on proxmox-LXC.
I spent like five minutes. All I did was run virt-host-validate.
Today I have a new customer who wants Stripe. I can imagine Stripe being harder than running KVM inside LXC.
Any tips on Stripe?
yep, that can do the trick however I would suggest that if you need to edit the network config, you probably should not be cheeping out on OpenVZ anyway.
no experience on strip at all - sorry about that.
The top bar text entries now break at my very high level of zoom.
I will have a look later I may have some bash scripts lying around. Maybe not the most actual ones but still working I hope.
How about some
dd if=/dev/zero of=/dev/yourdriveor some malformedmkfscommands?Sorry
not a lot I can do about that, at least it is not a functional change.
Here are proposed changes in
div class="Navigation-linkContainer". Maybe "Forum" should be "Talk".Without such article, the whole Wiki wouldn't have any sense.
š§ BikeGremlin guides & resources
Reminded by this (awesome) idea, wasn't a lowendwiki project started last year? I recall some conversation with @uptime about it. Maybe the two projects have some concurrence?
blog archives
LEA had some scripts that checked hosts (providers) for certain changes.
Not sure if that wiki is still available, perhaps wayback machine to find more info?
The scripts are long gone but Iām sure we can, as a group fix that.
Use this link in wayback machine to some more text about it.
http://lowendbox.com/blog/hosting-provider-tracker-available-on-low-end-wiki/
@AnthonySmith Yaaay!!! Thanks for making the change in the menu bar! Looks great again! On behalf of all the visually impaired people who need a lot of zoom, I do thank you so much for especial courtesy and consideration!
Kind sir, that line should probably read "On behalf of people who find it hard to read"
it covers a wider spectrum:
blog archives
Yes, that project was https://lowend.wiki/ , but it seems to be down now. In practice, it was mainly a site to learn about different providers. This said, I'm not sure whether it ever gained much traction.
I will volunteer time to edit the content so that words are top-notch. The market isn't looking too good now, so I have started my own copyediting and copywriting gig. I will contribute these skills to this project. @AnthonySmith let me know when content starts populating on the wiki.
If anyone needs a highly competent copyeditor or writer, do get in touch. LES folks will receive preferential pricing. I do a broad spectrum of editing and writing, from blog articles to academic manuscripts. If you prefer to learn how to write and edit your own work instead of relying on me, I am happy to arrange writing instruction and consultations too.
Just wanted to leave a mark for future to find easily if i need a proofread
thanks.
You can bookmark my website which is in my signature. Just say you are from LES and the pricing will be preferential.
i'm curious who are the three spirits (souls ?) in the LES logo ? maybe a good story for wiki too
i'm sure one of them is @AnthonySmith ... but dunno the other two
yes, this curiosity made me register
Generic people. The image was intended to show cooperation between people.
Community
Have you tried turning it off and on again?meh ... expected to be community founders
, especially after reading https://talk.lowendspirit.com/discussion/2317/a-year-in-les-reflections-thoughts-my-history-and-the-future-for-lowendspirit
I thought the 3 people represent:
Tap here if you don't know why.
