[INCEPTION HOSTING] Modeprobe issues whilst installing UFW and enabling it.[RESOLVED]
I am having problems on all three of the [INCEPTION HOSTING] 256MB servers that I recently purchased.
NL 95.46.198.25
US 104.161.79.98
UK 185.164.136.112
On all three servers I have attempted to install UFW and allow port 22. All goes fine until I enable UFW.
root@amd:~# ufw allow 22
Rules updated
Rules updated (v6)
root@amd:~# ufw enable
Command may disrupt existing ssh connections. Proceed with operation (y|n)? y
ERROR: problem running ufw-init
modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/4.15.0/modules.builtin.bin'
modprobe: FATAL: Module nf_conntrack_ftp not found in directory /lib/modules/4.15.0
modprobe: FATAL: Module nf_nat_ftp not found in directory /lib/modules/4.15.0
modprobe: FATAL: Module nf_conntrack_netbios_ns not found in directory /lib/modules/4.15.0
iptables-restore: line 4 failed
iptables-restore: line 75 failed
iptables-restore: line 31 failed
ip6tables-restore: line 4 failed
ip6tables-restore: line 142 failed
ip6tables-restore: line 31 failed
Problem running '/etc/ufw/before.rules'
Problem running '/etc/ufw/user.rules'
Problem running '/etc/ufw/before6.rules'
Problem running '/etc/ufw/user6.rules'
I've run this on Ubuntu 18, 16 and Debian 10, with the same issues.
Not had any issues with MrVM locations using same OS.
You probably don't have iptables installed and you need to read this: https://clients.inceptionhosting.com/index.php?rp=/knowledgebase/36/Iptables-csf-ufw-firewalld-or-vpn-software-problems.html
@AnthonySmith If I had only waited 30mins
Great thanks
I can confirm it works, I have just checked.
I wonder how many people having a generic issue over the next few years will google it, arrive here, read that KB, then run
touch /option.netfilterand report it did not fix anything.If you are that person in the future... hello and welcome from the past, I wonder who won the 2019 UK general election.
option.netfilter is specific to Inception Hosting, it is a work around for VZ7 (Virtuozzo 7) containers running under solusvm due to limitations within SolusVM's ability to write anything to container config files that gives you access to the required kernel modules to run certain things.
It was reported, acknowledged, given a reference for development, no idea when it will no longer be an issue, but rather than wait, this was the solution I came up with.
Switch to off topic, we can't have future people here
Carl Benjamin with NeUKIP.
It worked . . .
@Amitz is from the future, he knows what @WSS is up to next, even before him.
