In need of a dedicated server
I've looked trough hetzner auction so far so I figured I'd ask here as well.
Budget €65/mo
1gbps port
Xeon E3 or higher
RAM 16gigs+
PayPal or credit card
HDD/SSD/Nvme what ever fits the bill. But more space the better.
Edit: Location - Europe or USA
One very important thing, offers must come from companies older than 3 years and with good reputation. No shady crap what so ever.
Thank you for your time. I'll take a look at the offers (if any) tomorrow morning.
I'm the 85%. Also Elon likes memes hence he's an idiot.
How much transfer you need? Anyways here are a few offers that might work:
https://lowendbox.com/blog/hostsailor-e3-dedis-in-bucharest-romania-for-only-40-95-month/
(details on page)
https://portal.dedipath.com/cart.php?a=add&pid=142 (hybrid, 8 cores/16 threads from e5 2630L, 16gb ram, 500gb ssd, 30tb on 1gbps port)
https://www.nocix.net/cart/?id=343
(200tb transfer, e3 1240 v2, 16gb ram, 480gb ssd + 4tb hdd)
https://www.nocix.net/cart/?id=285
(200tb transfer on 10gb port, dual e5 2670, 64gb ram, 2 x 240gb ssd)
https://www.serverhunter.com/?search=HB7-W8F-ODR (sorted by storage/$ with max. 66 EUR/m.)
tl;dr other than Hetzner, the top ones seem to be EUServ Internet and SeedHost.eu
(if I understood correctly that HDD is your main priority - in case it's not, you can try changing the sort order to CPU benchmark/$ or RAM/$)
Check @qps , they fit the criteria, serious business, servers specs / price. Quickpacket
@serv_ee QuickPacket can offer this in any of our locations - Charlotte, NC, Chicago, IL, Los Angeles, CA, or Manchester, UK. Message me directly and we can discuss. Thanks
QuickPacket - Dedicated Servers in Ashburn, Los Angeles, Chicago
If you're still in need of a dedicated server feel free to check out ours, fits the budget you asked for:
Our company Dot-Tech LLC has been open since 2014.
DS-7
E3-1230v2
480GB SSD
32GB DDR3 RAM
DDoS protection
10TB Bandwidth
1Gbps Port
IPv4 /29 (5 usable IPs) + IPv6 /64
$54.99/month
Dallas, TX
https://billing.leveloneservers.com/cart.php?a=add&pid=57
You may check @ShockHosting 😁
https://shockhosting.net/dedicated
"an dedicated server" is not skint.
It should be "a dedicated server".
https://www.grammar.com/a-vs-an-when-to-use/
My bad. I always mix the two up.
Thanks for the suggestions everyone, will take a look in a short while.
Sorry for the double post but I found what I'm looking for. If any mod or admin wishes to close the topic please feel free to do so.
Also a big thanks to @ShockHosting
To close the thread, you just need to write on its own line:
/thread
If nobody else replies, the thread auto-closes after some time.
Smarter once again, thank you!
/thread
Per request.
