pfsense wireguard outbound connection
Hello, does anyone know if it is possible to have wireguard client in pfsense always use one specific gateway for its connection to a wireguard server. I have a dual wan pfsense setup and I know that in openvpn there is the interface option but not sure what the equivalent in wireguard is.
  • You want the wg connection to go through one specific WAN interface? One way is to add a static route for the remote wg peer via the desired WAN gateway.
    Thanked by (1)xyphos10
    yes this is what I need and thanks for the suggest, I will try it later
  • edited November 2021
    You can install Wireguard as an experimental WireGuard package from the Package Manager. Navigate to System > Packages, Available Packages. You can setup the way you want to there.
    Not everything that is faced can be changed, but nothing can be changed until it is faced.
