Alternatives to Nagios Monitoring?
What other self hosted monitoring solution do you use or recommend.
I can think of, NetData and Prometheus
I'd point, for reference, to these topics:
https://talk.lowendspirit.com/discussion/137/simple-free-monitoring-tool
https://talk.lowendspirit.com/discussion/270/lightweight-server-monitoring/
I'm considering graphite cause python
Prometheus is the way to go!
Installed Prometheus+grafana and it looks amazing! and is super easy to get it up and running.
Here is a screenshot of one of my nodes:
You can try Zabbix. Many companies are using it. Also, Zenoss is a good option, but it's a paid one.
I am lazy, just staying with hetrixtools
If it should be easy to setup and use you could try Centrion. The free solution should be enough for you.
can recommend icinga2, really nice setup, easy to automate, web ui does what it is supposed to.
Can be integrated with grafana and looks really nice.
also, if you dont want to setup much, checmkmk works out of the box most of the time. Automatic inventory creation, ...
Documentation isnt the best though.
It upsets me that it only runs from windows server but prtg is still the best imo
The same thing I asked before and I got the following recommendations,
nodequery.com by @Rahul
netdata, Munin by @AlwaysSkint
HetrixTools by @K4Y5
Nexa Racks - Reliable Web Hosting Company
Maybe flipping this the other way --
What do you want our of a monitoring solution @envix?
The dude (windows)
https://mikrotik.com/thedude
Grafana
@havoc but, with graphite, influx, or prom behind it
Looks like maybe you're using prometheus?
Why I'm glad you asked. It's node-exporter, prometheus and grafana. And it just so happens that I just finished writing a blog post on how to set this up
https://kaizen.today/grafana-prometheus-docker-monitoring/
(still need to make those other changes you suggested, but wanted to pump out some articles first
Zabbix?
QuickPacket - Dedicated Servers in Ashburn, Los Angeles, Chicago
The great thing with Grafana is that you can combine multiple servers into a single graph
I'm scraping data from Netdata into Prometheus, but haven't had time to set it up on all my VPSes yet.
