n8n - Workflow Automation Tool
n8n is an extendable workflow automation tool. With a fair-code distribution model, n8n will always have visible source code, be available to self-host, and allow you to add your own custom functions, logic and apps. n8n's node-based approach makes it highly versatile, enabling you to connect anything to everything.
https://n8n.io
Just found this - looks really cool. Anyone using it?
  • havochavoc OGContent Writer
    edited February 2022
    @AaronSS said: Anyone using it?
    Used Node Red (Javascript) for a while, which n8n is sorta based on
    There is also Zapier (paid I think) or Huginn (Python).
    I've switched to a blend of python / CI and docker though. Easier to just do python than learn a new tool tbh
