I also have a VPS with @AnthonySmith and a free DA license. Can recommend!
I have to say that I appreciate this form of response. There was no vehement response, no immediate dismissal - just a "not what I want".
Personally, I'd suggest setting up only the primary with an admin interface, and then syncing across to the secondary nameservers - less maintenance as long as you keep things firewalled tight. Extra management overhead if you don't have system setup to be secure is going to take more work.
https://www.lowendtalk.com/discussion/161872/anynode-cyber-monday-free-directadmin-1gb-ovz-from-12-yr/p1 Most likely your best bet.
Thanks, I already have one with them, I want to have a second dns server in another provider
There aren't many provider besides buyvm and intodns, who offers Free DA license. DA Internal license alone has a higher cost.
If 512MB works then you can get a slice.
Francisco
For DirectAdmin a minimum 1 GB of memory is required, according to this https://www.directadmin.com/install.php
512mb works fine. Might need a bit more temporary swap during compiling but it's fine, especially for just DNS.
Francisco
Or, ya know, ya could always..
:shrug:
My wc -l is 99.
Can confirm DNS is fine on 512MB.
Or less
Thanks for the info
@AnthonySmith in UK or @Francisco for other locations. I use them and highly recommend them.
As for 512MB for DA. As Fran said it’s fine. Just add a 1GB swap and all will compile fine.
