Need help on using DirectAdmin API (Unauthorized Error)
Hello!
I am having a weird issue when using DA's API with basic auth (MXroute).
I'm 100% certain the credentials are correct, however I'm getting "Unauthorized" error on every even requests, while the API works fine on every odd requests.
I'll put a screenshot of my current code, as well as the error I'm getting when the "Unauthorized" error happens. If anyone experienced this issue, or knows a fix for it, any input will be highly appreciated.
Thanks!
OK, so I found the issue.
It seems like when you send both the session cookie and the authentication credentials, DA will clear the session and log you out.
I was able to fix it by disabling cookie on requests.session.
Also in case you missed it, there's a typo in applicatoin/json (application)
kopya end-to-end encrypted cloud · piximg image and gallery hosting
Applicatoin is a good name for a new coin.
Lol that part was actually written by GitHub Copilot. Seems like there’s yet another reason to not use it?
