How to run wireguard in OpenVZ?
I have a bunch of old LES OpenVZ servers from Inception and wanted to run wireguard there (servers, although in wireguard everyone's a peer). However, when I try to run wireguard, I get
# wg-quick up wg0
[#] ip link add wg0 type wireguard
RTNETLINK answers: Operation not supported
Unable to access interface: Protocol not supported
[#] ip link delete dev wg0
Cannot find device "wg0"
Is it impossible to run wireguard in these containers or is it a PEBKAC issue? Do you recommend any of the userspace wireguard implementations and, if so, which?
  • IIRC enable TAP/TUN in SolusVM, wait for reboot, then run the script made by @Nyr ... πŸ˜‡ B)
  • edited July 2022
    # wg-quick up wg0
    Most likely the node doesn't have the WireGuard kernel module loaded, try asking if they can get it loaded?
    If you just want plain WG, there's wireguard-go; if you want a bit more, there's Tailscale.
    Hey, @InceptionHosting, is it ok to request for a LES offer?
    I was smart enpough to enable TUN! And I installed wireguard plus I already have the config for it.
    Do you mean this script?
    Yes, that script. I doubt the OpenVZ kernel is new enough to include Wireguard support. The script will pull in the userspace version... (At least it did for my debian VM's.)
  • edited July 2022
    Yeah, it pulls BoringTun. Which is fine because it works.
    For future reference, in addition to turning on tun, I had to do the inception magic to enable proper iptables by touch /option.netfilter and waiting half an hour.
    Very cool script, @Nyr.
