Yet Another Benchmark Script (YABS) - Linux Benchmarking Script using dd, iperf, & Geekbench
MasonMason OG
edited July 2020 in General
Some of you guys probably know about this little script already, but I just wanted to make a thread here to make others aware of it and gather input/suggestions to make it better!
Yet Another Benchmark Script (YABS) was created a few months back initially as an automated iperf script that I would use myself, then it evolved to include geekbench and dd tests as well. I then decided to tidy it up a bit and add it to GitHub. Here is the GitHub repo where you can review the script and get some additional information: https://github.com/masonr/yet-another-bench-script
Purpose: The purpose of this script is to quickly gauge the performance of a Linux-based server by benchmarking network performance via iperf3, CPU and overall system performance via Geekbench 4, and simple sequential disk performance via dd. The script is designed to not require any dependencies - either compiled or installed - nor admin privileges to run.
Benchmarking Tests
The script performs three main tests:
  • dd - to estimate disk performance. (disclaimer that read speeds may be heavily affected by cache)
  • iperf - to estimate network performance using parallel threads and by testing speeds in both directions (download and upload). Both IPv4 and IPv6 iperf tests are conducted (if available)
  • Geekbench 4 - to estimate total system performance by running a vast array of different CPU/memory intensive benchmarks. Both single and multi-core scores are given along with a link to view the complete system results. The URL to claim the test and add it to your Geekbench profile is written to disk.
Running the Script
The script is very easy to run and does not require any external dependencies to be installed nor elevated privileges to run:
curl -sL yabs.sh | bash
The script has been tested on CentOS 7, Debian 9, Debian 10, Fedora 30, Ubuntu 16.04, and Ubuntu 18.04.
Example Output
Here is example output from the script:
#                     v2020-01-08                    #
Wed 08 Jan 2020 07:33:21 PM UTC
Processor  : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
CPU cores  : 8 @ 4098.759 MHz
RAM        : 31Gi
Swap       : 0B
Disk       : 221G
dd Sequential Disk Speed Tests:
       | Test 1      | Test 2      | Test 3      | Avg
Write  | 291 MB/s    | 286 MB/s    | 281 MB/s    | 286.00 MB/s
Read   | 179 MB/s    | 188 MB/s    | 179 MB/s    | 182.00 MB/s
Provider                  | Location (Link)           | Send Speed      | Recv Speed
Bouygues Telecom          | Paris, FR (10G)           | 2.93 Gbits/sec  | 7.80 Gbits/sec
Online.net                | Paris, FR (10G)           | 7.79 Gbits/sec  | 5.20 Gbits/sec
Severius                  | The Netherlands (10G)     | 8.98 Gbits/sec  | 2.53 Gbits/sec
Worldstream               | The Netherlands (10G)     | 8.65 Gbits/sec  | 8.57 Gbits/sec
wilhelm.tel               | Hamburg, DE (10G)         | 7.80 Gbits/sec  | 9.03 Gbits/sec
Biznet                    | Bogor, Indonesia (1G)     | 752 Mbits/sec   | busy
Hostkey                   | Moscow, RU (1G)           | 905 Mbits/sec   | 449 Mbits/sec
Vultr                     | Piscataway, NJ, US (1G)   | 448 Mbits/sec   | 51.6 Mbits/sec
Velocity Online           | Tallahassee, FL, US (10G) | 1.74 Gbits/sec  | 1.61 Gbits/sec
Airstream Communications  | Eau Claire, WI, US (10G)  | 1.61 Gbits/sec  | 106 Mbits/sec
Hurricane Electric        | Fremont, CA, US (10G)     | 28.2 Mbits/sec  | 476 Mbits/sec
Bouygues Telecom          | Paris, FR (10G)           | 7.78 Gbits/sec  | 6.00 Gbits/sec
Online.net                | Paris, FR (10G)           | 2.86 Gbits/sec  | 5.74 Gbits/sec
Severius                  | The Netherlands (10G)     | 6.96 Gbits/sec  | 2.38 Gbits/sec
Worldstream               | The Netherlands (10G)     | 7.29 Gbits/sec  | 6.02 Gbits/sec
wilhelm.tel               | Hamburg, DE (10G)         | 4.64 Gbits/sec  | 8.93 Gbits/sec
Vultr                     | Piscataway, NJ, US (1G)   | 97.5 Mbit/sec   | 37.3 Mbits/sec
Airstream Communications  | Eau Claire, WI, US (10G)  | busy            | busy
Hurricane Electric        | Fremont, CA, US (10G)     | 348 Mbits/sec   | 505 Mbits/sec
Geekbench 4 Benchmark Test:
Single Core     | 5714
Multi Core      | 19758
Full Test       | https://browser.geekbench.com/v4/cpu/15115430
Feedback
I welcome any feedback you may have or any bug reports. Feel free to test it out and post your results.
-Mason
yabs daddy
  • In a short time at the other place I have seen users ask for YABS more often than other BMs. :+1:
  • Nice dude! Way to stay on top of it!
    edited January 2020
    Some hashing + ioping would be nice as well
  • I think that fio is a much better test but I already know the compiling issues, so if you could somehow make that happen, that's the best! I second @cybertech's ioping suggestion.
    Finally, is there a reason why you don't use Geekbench 5? From what I understand, Geekbench 4 may overweight the RAM portion of the score, and that has been changed in Geekbench 5.
  • If possible, add iperf3 Network Speed Tests to South America (Brazil).
  • MasonMason OG
    edited January 2020
    Any specific hash tests? Which ones are most useful?
    Working on fio! If I can get that working, that'd be ideal even if I have to maintain a 32-bit and 64-bit version.
    ioping was removed because it added unneeded complexity to the script. My previous iteration of YABS used ioping for read tests (while still using dd for write). I put ioping in there because I thought it'd be less influenced by the host's cache than dd, but I saw the same anomalies that I experienced with dd in the end. So to make things more simple, I took it out. I may revisit that decision if fio doesn't pan out.
    Mainly because Geekbench 4 is what I've generally been using for all my server testing and comparisons. It does make sense to update it to use Geekbench 5, though, so I'll probably add that in soon as the default and bake in a switch that'll still allow you to run Geekbench 4 tests, if desired.
    yabs daddy
  • Going to attempt to compile a static build of fio using Holy Build Box and/or the Meson Build system this weekend. Maybe one of these two tools will help since my initial efforts have proven fruitless.
    yabs daddy
    @Mason Compiling statically isn't that big of a deal. Just do a static on a Deb 7 and a CentOS build, and either of those two should work pretty much anywhere given all but LIBC is compiled into it. If you need help, I might be able to assist.
  • MasonMason OG
    edited January 2020
    Cheers, might take you up on that. Can't for the life of me figure it out but maybe that's because I am using a recent debian version. Compiled on a 4.15 kernel and it won't work on a 2.6 kernel machine. Compiled on a 2.6 kernel and it won't work on the 4.15 machine. I'll give debian 7 and centos a chance and call in the cavalry if I can't figure it out.
    Issues seem to be coming from the libaio and libc6 libraries.
    yabs daddy
    edited January 2020
    Those have different major revisions of each. Debian 7 is the lowest end for the libc required subs/services with standard libraries, whereas CentOS 7 is the Python user subgroup.
  • @Mason said: Issues seem to be coming from the libaio and libc6 libraries.
    Are you encountering issues with the libraries even when statically linking them? Do you get an error message?
  • MasonMason OG
    edited January 2020
    @Mason Just do a static on a Deb 7
    Deb 7 did the trick. Compiled it statically in a local vm and it's working on every vps+dedi I've tested so far (even an ancient cociu VM). Debian, Ubuntu, CentOS, and Fedora all tested. I assume I'll probably have to do a 32-bit version as well to cover my bases. Thanks for leading me in the right direction.
    Yes, they were statically linked, but I was hitting 'illegal instruction' and other ominous error messages when running the compiled binary on other machines. Compiling on Deb 7 seems to have done the trick, however.
    With this hurdle overcometh, I expect to have fio in YABS in place of dd/ioping by the end of the week after I do a whole bunch of testing. For the random r/w test, I think I'll be rolling with the recommended settings on BinaryLane's article --
    ./fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=4G --readwrite=randrw --rwmixread=75
    But I'll be reducing the file size to 1G (instead of 4G) and also will be adding in a timeout of 60 seconds to cut the command off if it's taking longer than that. I've already tested the timeout and it still spits out valid info if terminated, so it's fine if it stops early (edit: looks like the runtime flag has the same effect, but exits more cleanly). Add in the minimal flag to streamline things and we're golden.
    Does anyone else have any other recommendations for fio settings that would make sense in a holistic sense, since it's gonna be a "one size fits all" test?
    yabs daddy
  • Support for *BSD would be good
  • fio implementation is going smooth so far. Need to do a bunch of compatibility/QA testing before I commit the changes to the repo, but here's a preview of the results --
    mrowe@cicero:~$ ./yabs.sh -ig
    #                     v2020-01-14                    #
    Tue Jan 14 12:41:55 EST 2020
    Processor  : Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    CPU cores  : 8 @ 3567.647 MHz
    RAM        : 31G
    Swap       : 90M
    Disk       : 2.1T
    fio Disk Speed Tests:
               | Sequential  | Random
    Read       | 502.43 MB/s | 385.78 MB/s
    Write      | 451.38 MB/s | 331.61 MB/s
    Currently implementing four fio tests (sequential read, sequential write, random read, and random write). Here's the fio options I'm passing -- I welcome any feedback or suggested changes to these commands as I'm a fio noob.
    # fio sequential read
    fio --name=seq_r --ioengine=libaio --rw=read --bs=4k --iodepth=128 --size=1G --runtime=60 --gtod_reduce=1 --direct=1 --filename=seq_r.fio --minimal
    # fio sequential write
    fio --name=seq_w --ioengine=libaio --rw=write --bs=4k --iodepth=128 --size=1G --runtime=60 --gtod_reduce=1 --direct=1 --filename=seq_w.fio --minimal
    # fio random read
    fio --name=rand_r --ioengine=libaio --rw=randread --bs=4k --iodepth=128 --size=1G --runtime=60 --gtod_reduce=1 --direct=1 --filename=rand_r.fio --minimal
    # fio random write
    fio --name=rand_w --ioengine=libaio --rw=randwrite --bs=4k --iodepth=128 --size=1G --runtime=60 --gtod_reduce=1 --direct=1 --filename=rand_w.fio --minimal
    yabs daddy
  • edited January 2020
    That looks suitable for a VPS (Shared disk) so as not to punish neighbors as its only 4 minutes that the nodes performance will tank for other users.
    If you want a more real world test consider putting in a 3 second test that runs every 5 minutes for 24 hours then graphs the results over a day, far more indicative of real world use/ performance :)
    Yeah, tried to make it as short as possible but still get a valid result. For most systems, it hopefully won't take the full 60 seconds to read or write the 1G file so should complete much sooner. The runtime is more of a precaution to cut off any tests that are taking an extreme amount of time.
    That'd be interesting. Maybe in YABS^2, I'll make a version of this that characterizes performance over a 24-hour period. Would be pretty neat.
    I've parsed and added in IOPS as well for each of the four tests since fio spits those out and they might be useful for some --
    Example:
           | Sequential     (IOPS) | Random         (IOPS)
    Read   | 399.45 MB/s   (99.8k) | 209.84 MB/s   (52.4k)
    Write  | 219.36 MB/s   (54.8k) | 200.68 MB/s   (50.1k)
    yabs daddy
  • Looking good!
  • Nice work, @Mason. I think a 1G file is acceptable, although I probably will still go with a 4GB test file for my own benching mainly because a larger test file will more likely even out spikes, if any.
    I am not sure how to do a 3-second test that can capture everything lol. My own homebrew script takes several minutes to complete all my tests. Well, I guess YABS is really not meant as an extended test because it needs to go with the lowest denominator. Right now, with both sequential and random speeds plus IOPS, it is good enough.
    My recommendation for the fio command is that you can use the entire binary lane sample, but change the --rwmixread=75 to --rwmixread=50 so that the test will do a 50% read and 50% write. I think it is better to read and write the same amounts of data.
  • @poisson said: I am not sure how to do a 3-second test that can capture everything lol.
    Personally I am not sure how a 1GB or 4GB or 60 second test captures anything you you are ever likely to use a VPS for in the real world.
    The same can be said for all kinds of research. That's why we design methodologies that increase the probability of being correct.
  • MasonMason OG
    edited January 2020
    Thanks for the feedback @poisson and @AnthonySmith, mucho appreciated! After having a lengthy discussion with Falzo and thinking about some of the feedback here, I've implemented some changes:
    • I scrapped the sequential speed tests. People might be used to seeing them, but they're essentially useless as they aren't testing real-world conditions, so I guess it's best not to continue the facade that anything of value can be interpreted from these results
    • Increased the test file size from 1GB to 2GB
    • Decreased duration of tests from 60s to 30s (most machines should still complete the test before hitting the time limit)
    • Using 6 independent fio tests (4k block size - read-only, write-only, and mixed rw (50/50); 64k block size - read-only, write-only, and mixed rw (50/50)
    Here's an example of the current output using an ExtraVM NVMe VPS --
               | 4k Block Size    (IOPS) | 64k Block Size   (IOPS)
    Read-Only  | 210.38 MB/s     (52.5k) | 723.15 MB/s     (11.2k)
    Write-Only | 419.43 MB/s    (104.8k) | 614.28 MB/s      (9.5k)
    Mixed RW   | 400.44 MB/s    (100.1k) | 965.31 MB/s     (15.0k)
    Another example with a Dedi w/ SSD (was also doing other tasks at the time...) --
    Read-Only  | 56.75 MB/s      (14.1k) | 157.57 MB/s      (2.4k)
    Write-Only | 195.83 MB/s     (48.9k) | 115.27 MB/s      (1.8k)
    Mixed RW   | 102.23 MB/s     (25.5k) | 186.61 MB/s      (2.9k)
    I'm debating whether or not to add another set of three tests for 1M block size, but I think I'll keep it as is for now so the test doesn't take all damn day to run :tongue: . I still have a ton of testing to do to make sure all is well when testing this on other OSes before it hits the repo.
    yabs daddy
    @Falzo is indeed the man to ask. This looks good enough to me, although for a general benchmark I would say mixed read-write would suffice. It is good to know pure read and write iops and bandwidth, but you really want to know the mixed performance because that is the environment most tests will be conducted in. No harm leaving them, but if you want to shave seconds off the overall testing time, those would be on the chopping block for me.
    Actually, you can work arguments into your script, right? You can offer 4k, 64k, 512k and 1M block sizes and allow them to be tested if the correct arguments are passed. So the default will be 4k and 64k, but the full can be activated of necessary.
    I wonder if we can determine numbers to give an indication of excellent, good, fair and poor iops for different block sizes. This will require some testing to determine appropriate cutoffs that are reasonable but it will help people interpret the numbers more meaningfully.
    ExtraVM 100K Write IOPS
  • @poisson said: but you really want to know the mixed performance because that is the environment most tests will be conducted in
    I got a similar sentiment from Falzo as well, so I think I may be overestimating the importance of including read/write-only tests. If I cut those out, I can instead put in 4 tests using mixed RW (50/50) with the block sizes you pointed out. Let me throw something together really quick and see how it looks :)
    I personally don't like the idea of adding in (bad/good/great) indicators of performance from these tests for several reasons. The cutoffs between them can be arbitrary and essential our opinion of what "good" means. In addition, what's considered good today might be considered poor 2 months from now as hardware and expectations change. If it's something a lot of people want, then I'll reconsider.
    yabs daddy
    Please don't. Morons who pay $4/yr for a special which is capped to 2Ghz tend to bitch a lot about these bogus statements.
  • All 4 tests are random rw tests with varying block sizes. Here's what it looks like
    Block Size | 4kb           (IOPS) | 64kb          (IOPS)
    Read       | 201.19 MB/s  (50.2k) | 456.29 MB/s   (7.1k)
    Write      | 201.72 MB/s  (50.4k) | 458.69 MB/s   (7.1k)
    Total      | 402.91 MB/s (100.7k) | 914.98 MB/s  (14.2k)
    Block Size | 512kb         (IOPS) | 1mb           (IOPS)
    Read       | 450.27 MB/s    (879) | 417.77 MB/s    (407)
    Write      | 474.19 MB/s    (926) | 445.60 MB/s    (435)
    Total      | 924.46 MB/s   (1.8k) | 863.38 MB/s    (842)
    yabs daddy
  • It's looking great @Mason. I'm not sure if you are describing the test anywhere in the script output but may I suggest that add "(mixed r/w 50/50)" on the table header above. So, it says fio Disk Speed Tests (mixed r/w 50/50)
    Thanks @beagle! I changed it to "fio Random R+W Disk Tests" shortly after posting what the current output looks like, but I like your suggestion better so I'm going to roll with that! Thanks again :)
    A family emergency came up this past weekend, so I haven't worked on it too much. Prior to the weekend, I did get all the 32-bit juices flowing, so it's 32/64-bit compatible now. I also did some testing with IPv6-only VMs as well and made some changes to make it compatible on that front. Unfortunately both GitHub (raw.githubusercontent.com via Fastly) and Geekbench (cdn.geekbench.com) CDNs are not IPv6 ready for whatever reason. I did manage to get a workaround going for GitHub, but not Geekbench. So for now, unless I add Geekbench's files to my repo (which I don't think I'm allowed to do), Geekbench tests will only be performed on IPv4 (either native or NAT) enabled machines.
    yabs daddy
    You could always haproxy it externally, because hosts.cx is IPV4 only as well.
  • @poisson said: I think it is better to read and write the same amounts of data.
    You're very unlikely to hit that in real life though - Usually you have far more reads vs writes, except in some particular cases (eg. a database server could be write-heavy if it's primarily for transactions instead of analytics).
    edited January 2020
    the thing is that rwmix=50 write IOPS reflected are high.
    at 75 the read is higher, write is lower, which does not reflect what the highest IOPS are.
    i dont know maybe do a dedicated half file size of read, and then half write (e.g. 2GB read test, 2GB write test) maybe, or if rwmix does both operations at the same time, then maybe it does simulate real world performance, then in any case it would be nice if there's a reference grading based on IOPS results from:
    • LEB Summerhost
    • Bad
    • Mediocre
    • Good
    • Excellent
    • NVMe
    in the context of rwmix=75 assuming this is close to real usage.
    also when doing fio sometime vps i observe IOPS drop to 0 (fluctuate up and down), but the result end up to be a good average.
    if this behaviour is concluded to be bad for real usage, maybe it can be discussed for future tests to also detect this "anomaly"
    I don't disagree, but for me when it is 50-50 with a 4GB test file size, I think there is enough data both reading and writing to give a good overall view of performance. I would also argue that with a 50-50 yes, the reading IOPS will go down, but you are likely to get performance that exceeds this value, while for writing, you get a value that is closer to the true capability of the disk than one that is artificially low and may make people mistakenly conclude the writing sucks (and I think a lot of people want to see accurate writing speeds more than they want to see flashy read numbers).
    I don't think we can ever come to an agreement what's the best, but I think 50-50 is good for the aforementioned reasons.
  • We'll probably all have to agree to disagree. The past few comments really showcase something that I've been struggling with -- creating a "one-size-fits-all" test is HARD. lol :tongue:
    yabs daddy
  • hey @Mason thanks a lot for your work! as you probably already know I love it!
    now finally everything I like to use for testing (geekbench, fio, iperf) is bundled in one script and don't need to lookup download-links and stuff anymore.
    finally signed up here just to let you know ;-)
  • Big update just pushed to the repo finally with a whole lot of goodies (@Falzo - fio is finally here!). I tested the script with pretty much every Hetzner and Vultr CentOS, Ubuntu, Debian, and Fedora templates to make sure it's pretty robust and compatible with most Linux-based OSes..
    Biggest updates:
    • fio - fio disk benchmarking tool is added to the script in place of the sequential (dd) test
    • IPv6-only compatibility - the script will now work on IPv6-only VMs (instructions in readme) (Geekbench 4 won't work since it requires IPv4 to download the files - might look into workaround)
    • 32-bit compatibility - if a 32-bit architecture is detected, then the 32-bit fio and iperf3 binaries will be downloaded instead
    Pre-compiled binaries are included in the project's bin directory. The readme explains why these are necessary, but it pretty much boils down to attempting to make running the script as simple as possible for the user. Please test it out and let me know if you have any trouble with the new script. I've tried to make it as robust as possible, but I'm sure I've missed some edge cases :)
    Here's the current output --
    #                     v2020-02-04                    #
    Tue Feb  4 19:04:24 UTC 2020
    CPU cores  : 8 @ 800.098 MHz
    RAM        : 31G
    Swap       : 0B
    Disk       : 221G
    Read       | 69.37 MB/s   (17.3k) | 106.51 MB/s   (1.6k)
    Write      | 69.57 MB/s   (17.3k) | 107.07 MB/s   (1.6k)
    Total      | 138.94 MB/s  (34.7k) | 213.59 MB/s   (3.3k)
    Read       | 133.52 MB/s    (260) | 141.90 MB/s    (138)
    Write      | 140.61 MB/s    (274) | 151.35 MB/s    (147)
    Total      | 274.13 MB/s    (534) | 293.26 MB/s    (285)
    Bouygues Telecom          | Paris, FR (10G)           | 1.41 Gbits/sec  | 1.13 Gbits/sec
    Online.net                | Paris, FR (10G)           | 1.44 Gbits/sec  | 1.29 Gbits/sec
    Worldstream               | The Netherlands (10G)     | 1.18 Gbits/sec  | 1.22 Gbits/sec
    wilhelm.tel               | Hamburg, DE (10G)         | 805 Mbits/sec   | 1.13 Gbits/sec
    Biznet                    | Bogor, Indonesia (1G)     | 768 Mbits/sec   | 38.5 Mbits/sec
    Hostkey                   | Moscow, RU (1G)           | 503 Mbits/sec   | 686 Mbits/sec
    Velocity Online           | Tallahassee, FL, US (10G) | 2.74 Gbits/sec  | 2.67 Gbits/sec
    Airstream Communications  | Eau Claire, WI, US (10G)  | 3.36 Gbits/sec  | 963 Mbits/sec
    Hurricane Electric        | Fremont, CA, US (10G)     | 6.34 Gbits/sec  | 3.76 Gbits/sec
    Bouygues Telecom          | Paris, FR (10G)           | 1.44 Gbits/sec  | 1.25 Gbits/sec
    Online.net                | Paris, FR (10G)           | 1.36 Gbits/sec  | 972 Mbits/sec
    Worldstream               | The Netherlands (10G)     | 1.19 Gbits/sec  | 1.20 Gbits/sec
    wilhelm.tel               | Hamburg, DE (10G)         | 826 Mbits/sec   | 1.14 Gbits/sec
    Hurricane Electric        | Fremont, CA, US (10G)     | 6.36 Gbits/sec  | 2.95 Gbits/sec
    Single Core     | 5587
    Multi Core      | 19093
    Full Test       | https://browser.geekbench.com/v4/cpu/15200550
    yabs daddy
    Biggest updates:
    > #              Yet-Another-Bench-Script              #
    > #                     v2020-02-04                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 31G
    > Swap       : 0B
    > Disk       : 221G
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > iperf3 Network Speed Tests (IPv4):
    > iperf3 Network Speed Tests (IPv6):
    > Test            | Value
    > Single Core     | 5587
    > Multi Core      | 19093
    You are not sexy.
    You are SEX!
  • Hey @Mason... yabs.sh is available to buy right now... maybe we can have a shortened URL? :) Pretty please?
    I was eyeballing that domain a couple weeks ago. Screw it... let's do it. Just registered it, I'll set up a shortened URL soon(tm). I'll probably just have it redirect to the github page fwiw. I'd rather keep all files and such on there for openness sake and so I don't have to worry about syncing the files.
    yabs daddy
  • Awesome updates to my favorite bench script. Thank you @Mason!
    Could also set up yabs.sh/run or something as a 301 redirect to the raw.githubblahblah URL too :) -- and perhaps a yabs.sh/run6 for the IPv6 version!
    Thank you, BTW! I will have to try this on my servers this weekend.
  • Nice going. Waiting for the update to Geekbench 5 next!
    That's the next change I have planned right now. I'll let users pass a flag to still use the Geekbench 4 test, but once I have Geekbench 5 test in there, that'll be the new default.
    yabs daddy
  • MasonMason OG
    edited February 2020
    Domain is set up now with appropriate redirects.
    How's that for short? :)
    Redirection is based on user agent. Curl/wget requests will be redirected to the raw script content, while http requests will go to the main github project page. Thanks again for the neat idea! I'll get the docs updated soon.
    Edit: Will have to test and work on IPv6 as I don't think this will work yet on IPv6-only VMs.
    yabs daddy
    You sir are the MVP of benchmarking scripts IMO. Thank you!!!
  • Thanks @Mason for the tweaks and folks for suggestions ....
    One silly question: is it typical to see @ 20-24 GB bandwidth consumption for every instance the updated YABS is run?
    Thanks
    Thanks
    Honestly, I'm not sure but that's something I should probably test and put in the readme somewhere ;)
    yabs daddy
    Nah, it usually uses 40,503GB. Ya know, and at least 100% of each core for 10 days. Gotta make sure that $2/mo service you bought is prem.
    Actually for a $4 /year, 2 00 GB/month plan I will only be able to run YABS less than 8 times. That’s the concern. Got to keep that idler in shape.
    You can always SIGKILL/SIGSTOP it and hope it doesn't use any real ticks.. might be able to double that.
  • looks good .
