so how to open the instance? deploy a script for monitoring it?
@frakass said: so how to open the instance? deploy a script for monitoring it?
The movie?
If it’s not broken, keep fixing it until it is. Blink twice if you agree.
Use the API to deploy, you may have luck.
At the first sight, I though you were talking about stardict, which is a fantastic open source dictionary software.
MicroLXC is lovable.
@somik said: @frakass said: so how to open the instance? deploy a script for monitoring it? The movie?
Stardust has Daredevil and Superman fighting each other in it.
@AC_Fan said: @somik said: @frakass said: so how to open the instance? deploy a script for monitoring it? The movie? Stardust has Daredevil and Superman fighting each other in it.
@AC_Fan said:
Can't say I have watched this movie... Maybe i'll pick it up.
@giang said: Use the API to deploy, you may have luck.
Yea use API.
Yep. I've concluded it's a waste of time even at free
@havoc said: Yep. I've concluded it's a waste of time even at free
No, they actually just work, and given you can get 2 for just 1€ its a steal.
People are talking about scaleway.com starlight learning instances, yes ?
@Neoon said: @havoc said: Yep. I've concluded it's a waste of time even at free No, they actually just work, and given you can get 2 for just 1€ its a steal.
@Neoon said:
Yeah not bad, but I just don't have the patience to jump through hoops like that.
Also, stuff like oracle free tier will absolutely wreck stardust. (Assuming oracle doesn't hate you & randomly deletes your acc ofc).
Who has a link to an API Scaleway guide?
https://www.scaleway.com/en/docs/compute/instances/api-cli/creating-managing-instances-with-cliv2/
The movie?
Yea use API.
