help to mount vps storage
in Help
hello, i have two vps one vps storage is small, and 2nd vps storage 1TB, so i want to mount storage vps on normal vps with faster read and write speed.
so how can i do it? anyone have any tutorial?
Thanks
To mount securely but not the fastest.
https://phoenixnap.com/kb/sshfs
To do so with nfs.
https://linuxize.com/post/how-to-mount-an-nfs-share-in-linux/
mount.nfs: Connection timed out
this happen
If you have a firewall enabled on ether VPS you will need to whitelist the IP of the opposing VPS so they can communicate.
both vps os new and fresh
can you have more ways?
seems i have mounted but i cant access the direcory.
error is: cd: /media: Permission denied
I've used SSHFS (in FrankZ's first post) for many years with success in applications like this.
its possible via rclone?
use caching
For SSHFS:
For rclone:
For S3FS:
β¨π Low end deals Telegram tracker: https://t.me/lowendweb
I would recommend NFS via WireGuard if there isn't a private network between the servers.
Website: thomassen.sh
i need your help, i've pm you
Buy an hour of @skorupion's life to help you with this
"The imitator dooms himself to hopeless mediocrity." β Ralph Waldo Emerson
mount successful but jellyfin download won't work via transmission.
it's said fail permission wrong, i already fix file permission but still same.
