A Bash Script to Auto Renew Minio SSL
Hello everyone,
I wrote a script using bash to help renew lets encrypt ssl issued using on a minio instance. Minio is an s3 compatible storage. Basically, the ssl is issued via certbot but files need to be moved around. I found myself every now and then having my minio ssl expired and I didn't know. so i created this script to check daily when the hostname ssl expires and to renew it automatically. hope it helps someone with a similar need.
#!/bin/bash
PUSHOVER_API_TOKEN='xxxxx'
PUSHOVER_API_USER='xxxx'
HOSTNAME=$(hostname)
DEFAULT_PRIVATEKEY_LOCATION=/etc/letsencrypt/live/$HOSTNAME/privkey.pem
DEFAULT_CERTIFICATE_LOCATION=/etc/letsencrypt/live/$HOSTNAME/fullchain.pem
MINIO_USERNAME=minio-user
MINIO_PRIVATEKEY_LOCATION=/etc/minio/certs/private.key
MINIO_CERTIFICATE_LOCATION=/etc/minio/certs/public.crt
certexpiredays(){
EXPIREDATE=$(openssl x509 -in $MINIO_CERTIFICATE_LOCATION -enddate -noout | sed "s/.*=\(.*\)/\1/")
EXPIRE_DATE_IN_SECONDS=$(date -d "${EXPIREDATE}" +%s)
NOW_IN_SECONDS=$(date -d now +%s)
DATE_DIFF_IN_SECONDS=$(( (EXPIRE_DATE_IN_SECONDS - NOW_IN_SECONDS) / 86400 ))
echo $DATE_DIFF_IN_SECONDS
notify(){
STATUS=$1
local TITLE="Renewal of Minio SSL"
if [[ $STATUS -eq 0 ]]
then
local MESSAGE="SUCCESS! Minio SSL successfully replenished for https://$HOSTNAME:9000"
else
local MESSAGE="FAILED! Could not complete SSL renewal for minio. Status code: $STATUS for https://$HOSTNAME:9000"
fi
local SOUND=siren
local TIME=$(date)
local PRIORITY=0
curl -s \
--form-string "token=$PUSHOVER_API_TOKEN" \
--form-string "user=$PUSHOVER_API_USER" \
--form-string "title=$TITLE" \
--form-string "message=$MESSAGE" \
--form-string "timestamp=$TIME" \
--form-string "sound=$SOUND" \
--form-string "priority=$PRIORITY" \
https://api.pushover.net/1/messages.json
#0.Check if renewal is needed in the first place
DAYS_TO_SSL_EXPIRY=$(certexpiredays)
if [[ (( $DAYS_TO_SSL_EXPIRY < 5 ))]]
then
#1.Renew SSL
echo "===Commencing SSL renewal...==="
echo 2 | sudo certbot certonly --standalone -d $HOSTNAME
if [ $? -eq 0 ]
then
echo "==>OK! SSL for minio has been requested successfully."
echo "==>Copying SSL files...."
#2. Copy SSL files to correct directory
sudo cp -v $DEFAULT_PRIVATEKEY_LOCATION $MINIO_PRIVATEKEY_LOCATION
sudo cp -v $DEFAULT_CERTIFICATE_LOCATION $MINIO_CERTIFICATE_LOCATION
if [ $? -eq 0 ]
then
echo "==>OK! SSL files copied successfully..."
#3. Change ownership of the SSLs
sudo chown $MINIO_USERNAME:$MINIO_USERNAME $MINIO_PRIVATEKEY_LOCATION
sudo chown $MINIO_USERNAME:$MINIO_USERNAME $MINIO_CERTIFICATE_LOCATION
if [ $? -eq 0 ]
then
#4. Restart minio service
sudo systemctl restart minio
pgrep minio >/dev/null 2>&1
STATE=$(echo $?)
if [[ $STATE == 0 ]]
then
echo "==>OK! Minio restarted successfully..."
echo "==>SUCCESS! SSL for minio replenished successfully."
notify 0
else
echo "==>FAILED! Could not restart minio."
notify 1
exit
fi
fi
else
echo "==>FAILED! There was an error copying SSL files."
notify 2
exit
fi
else
echo "==>FAILED! There was an error requesting for SSL for minio."
notify 3
exit
fi
else
echo "==>SSL for minio still valid for $DAYS_TO_SSL_EXPIRY days. Nothing to do. Bye"
exit
fi
thank you
And by the way, you need to set a cron job to run the bash script above daily.
