KillBill
Not_Oles
Provider
Hello!
A friend mentioned KillBill billing platform:
Is anybody aware of any Low End provider who uses KillBill?
Thanks!
Tom
Not_Oles
Provider
Hello!
Thanks!
Tom
Never heard of it to be honest. I've gone through a bunch over the years, settled on whmcs 15 or so years ago and now have so many custom plugins its not wrth or easy to switch π
microtronixdc.com - Colocation, Dedicated Servers, Full-Rack options, VPS. John 3:16 - Jesus Saves!!
Massive Network Bandwidth options with Fiber throughout, up to 100Gbps connections! Always-On DDoS Mitigation for all traffic!
Hi @jfreak53! Yeah, I never heard of KillBill either. But it seems to have at least some reasonable level of development.
KillBill is very much a back-end system only. The last time I looked at it, there was no front-end user interface - all interaction was through the API. So, I guess if you have already built your own front-end portal for customers, it could be possible to integrate KillBill for the back-end.
QuickPacket - Dedicated Servers in Ashburn, Los Angeles, Chicago
Hi @qps! Yeah, adding a front end interface would be a significant opportunity for custom Low End development. Thanks for mentioning this opportunity!
It's a death proof software for the reservoir dogs.
Probably a good fit if you have eight hateful customers...
π§ BikeGremlin guides & resources
Quite. It has a huge hardware overhead, so be sure your datacenter can commit Four Rooms at least.
