Low TB Storage Deals
Who are the good for value storage deals for backups these days?
Low TB range (call it 4-8TB); pure backup (no seedboxing or anything) so low CPU/RAM requirements - even stuff like Hetzner's SB stuff is fine.
And yes, Hetzner sets a pretty low bar at ~$14/months for 5TB but it would be nice to get below that (plus I already use them for some stuff and it would be better to be a bit more diverse with backups)
  • edited March 2024
    @ahnlak said:
    Low TB range (call it 4-8TB); low CPU/RAM requirements
    This offer (affiliate link) looks like the best fit for all the requirements above. That's a ref, but it's more than well-deserved. I have one myself for quite a while, no complaints.
    If you want more space, then check the other plans from the products groups on the left. However, they will also have more RAM and cores.
    ☰ VDS & Storage — Budget AMD EPYC VDS (ref) from $4/m / Big HDD VPS (ref) from $2/TB/mo / EPYC/Gold/Platinum dedis (ref) w/ GPU support
  • Yes, I've seen that (and it was one of the things that poked me back into looking at backup options), but ... there might be other options?
    If I just meant "I'm too dumb to read a thread on the front page", I'd have said that ;-)
    This offer looks like the best fit for all the requirements above. That's a ref, but it's more than well-deserved. I have one myself for quite a while, no complaints.
    Cheers; that was the name lurking at the back of my mind that I couldn't quite remember!
  • @ahnlak said: there might be other options?
    1 vCore CPU, 2GB DDR4 ECC RAM, 4TB HDD RAID-5 (NVMe Cached), 20TB @ 1Gbps monthly traffic usage, 1 IPv4 address, 1 IPv6 address
    Let's do it now for €36,60/year VAT incl.
    You can add SIIX, BGP Service and many other features.
    DM for info.
    LumanexAI: Our in-house AI model for free 🚀
    I've edited the post to add/disclose the link being affiliate info.
    Affiliate links should be disclosed.
    Sure, I'm aware of this rule. That's why I wrote "That's a ref, but it's more than well-deserved"
    Or that wasn't enough?
    I have to admit, I read it as something more like "that's a rec(ommendation)" and didn't take in that it was an affiliate link. Then again, I just hovered over it, saw Serverica's name and went straight there (sorry!) so it all worked out :lol:
  • 1fichier is king in that price/size range, especially if using it from a residential IP
    Apparently not.
    I thought it's a good idea to edit the post and write the comment, to avoid any misunderstanding, further discussion about that, and post flags.
    Relja
  • I have a HostHatch 2023 10TB BF deal that I'd be interested in transferring at cost of remaining balance + transfer fee if you're interested. As I understand it, you'd take over the remainder of my term (through 2025-01) and then have the option to continue at the same rate.
    Details:
    • 10 TB Storage
    • 2 CPU Cores
    • 4 GB RAM
    • 40 TB Bandwidth
    • 2 year term at $300/year -> $12.5/mo (for 10TB!)
    • Billing cycle restarts on 2025-01
    I outgrew it and moved most of my stuff to a dedicated box with more storage. :scream:
