Strange Network issue
edited April 29 in Help
hi
What can one check if :
  • network interfaces are up via dhcp
  • resolv.conf has google nameservers
  • i can ping for example 1.1.1.1
  • dns works "resolves hostname" if i can ping www.google.com
  • traceroute works .. at one hop it delays but its oky
  • ipv6 i have disabled to limit checks.
  • i can restart the network service
  • no firewall exists
  • mtu is 1500
my problem is if i try to
wget www.google.com
it resolves ip but never downloads the index page.
http network just pauses.
what elsei can check to finger the problem?
any more checkes/ideas helps.
Thanks in advance
ehab
  • Maybe try adding the "--inet4-only" flag to wget.
    wget --inet4-only www.google.com
    Thanked by (1)ehab
  • Sounds like dropped packets during SSL handshake
    Begin by using tcpdump to verify that there are dropped packets or retransmissions
    Thanked by (1)ehab
  • verbose flags, debug flags, strace that wget see what it hangs on
    Thanked by (1)ehab
  • @ehab said: mtu is 1500
    And what if you try MTU 1400, would it start to work?
  • skorousskorous OGSenpai
    edited April 29
    This is a good one because everything else that has worked is smaller packets. I actually just had this problem although in my case I had to go down to 1300 because I was running a tunnel inside a tunnel through a partially brain damaged firewall.
  • edited May 1
    ----- will update soon
  • vyasvyas OGSenpai
    edited May 2
    A reboot dropping of pants didn’t fox it ?
    Thanked by (1)ehab
  • here are images
    boot process shows it picks up ip and can ping
    next images shows more detailed interface info
    @don_keedic any ideas what to test next.
    this is minimal boot, i cannot install tools to debug more but i have just gotten custom iso option i will try to find different distro with more troubleshooting tools
  • Try ip -s link show eth0 and see if there are errors and dropped packets. It's not reliable but it's a start.
    Try with lower MTU values as @rm_ said with (i.e ip link set eth0 mtu 1400)
    You can also check with ping -M do -s 1472 1.1.1.1 and lowering values until you do not see "message too long"
    I think you have dropped packets for some reason, it can be some misconfigred firewall somewhere, NIC driver issue, NIC hardware issue or even a faulty eth cable.
    What machine is this?
    Thanked by (1)ehab
  • edited May 4
    i think i found some lead with this issue.
    installing the vm with hoster template and enabling ipv6 the
    wget www.google.com ### workds
    if i disable the ipv6 and try again it fails.
    the vm is a storage NAT from hostbrr @Labze - Ticket #4126405
    i will add to the ticket this finding.
    Thanked by (1)SashkaPro
    I'll be the first to tell you networking is not my strong suit but at this point, I'm determined to help you figure it out.
    This is one of those things I know for a fact that will come up again randomly sometime in my future and I'm sure the fix is probably on some obscure messageboard that google doesn't index anymore, so for the sake of future ehabs, we're going to have to get this figured out here and now.
    **the vm is a storage NAT from hostbrr @Labze - Ticket #4126405 **
    If you were at OGF, you'd get the "funny", clichéd response, "response time doubled, thanks for using low end support hurr durr" but good on you for trying to seek a fix, for a week, before contacting them. When a provider does have an issue, it's always better to have more information from a client than just "it doesn't work" so hopefully, given all the information provided, he'll be able to quickly diagnose if it's something on his end.
    Thanked by (3)ehab skorous RapToN
  • turns out to be provider blocking outgoing port 80
    i had to change alpine repos from http to https
    hopefully they fix it soon
    thanks all for your help
  • /close
  • AuroraZeroAuroraZero ModeratorHosting Provider
    @ehab said:
    /close
    shakes his head
    Thanked by (1)skorous
