Installing plan9port in my Chromebook's Linux Container
plan9port is a Unix/Linux user space implementation of Plan9 from Bell Labs, The Plan 9 operating system was the successor to Unix at Bell Labs, where Unix previously had been developed.
Today I had some fun installing plan9port on my Lenovo Duet 5 Chromebook. I like the Duet 5 because of its brilliant 13 inch OLED touchscreen. Also, the Duet 5 is small, light, and inexpensive compared to other OLED laptops. The Duet 5 will run Android apps. And built-in to Chrome OS is the ability to run Linux containers. Today's plan9port install was inside one of the containers.
Here is a list of the commands I ran to install plan9port on my Duet 5. If I were doing the install again, I probably would install the four additional, required -dev packages prior to running /use/plan9/INSTALL. Today, I re-ran INSTALL four times following successive failures caused by missing header files.
2042 cd /usr
2048 sudo git clone https://github.com/9fans/plan9port plan9
2050 cd plan9
2052 sudo /usr/plan9/INSTALL
2057 sudo apt-get install libx11-dev
2068 sudo apt-get install libxt-dev
2078 sudo apt-get install libfontconfig1-dev
2090 sudo apt-get install libxext-dev
* Add these to your profile environment.
PLAN9=/usr/plan9 export PLAN9
PATH=$PATH:$PLAN9/bin export PATH
Here are Plan 9's rc shell and the sam editor running after the successful install.
chronos@penguin:~$ cat /etc/debian_version
12.6
chronos@penguin:~$ which rc
/usr/plan9/bin/rc
chronos@penguin:~$ rc
% man sam
% sam -d
q
Getting started with plan9port is easy. Please see the getting started tips on Github at Issue 97 in the plan9port repository.
Based on limited testing -- I fired it up once -- my Duet 5's plan9port graphical editor, Acme, seems to work too. For my use, I'm usually happy with the command line tools, but here is a good, brief introductory reference list for plan9port's Acme graphical editor.
