Owncloud trusted_domain issue after upgraded from 10.10 to 10.11[SOLVED]
After updated my Owncloud container from 10.10 to 10.11, it indicates follow error
You are accessing the server from an untrusted domain.
Please contact your administrator. If you are an administrator of this instance, configure the "trusted_domains" setting in config/config.php. An example configuration is provided in config/config.sample.php
- Access from 127.0.0.1:8080 via ssh remoting also get same error
- Change the variable trusted_domainsinconfig.phpwon't work
Anyone gets the same problem?
Ontario Dildo Inspector
Sounds to me like maybe your proxy is not forwarding the information about the host correctly and or a wrong trusted_proxies setting.
There was even a change regarding this included in the 10.11 release (see: https://github.com/owncloud/core/pull/40148).
I double checked the log of owncloud & nginx, the domain info has been handled correctly.
It has been solved by adding the env
OWNCLOUD_TRUSTED_DOMAINSrather than modifyconfig.phpIt should a bug I suppose.
