Finland! NAT VPS' available for paid beta testing now
So far the beta has been a success. Now that we've completed automated setup on the MicroNode panel we're going to offer a paid beta:
Micronode nat100m - Our popular NatVPS' come to micronode!
- Single Core CPU (Intel(R) Xeon(R) Gold 6240L CPU @ 2.60GHz)
- 128MB RAM
- NAT IPv4 (20 ports + SSH port)
- Gigabit Port (Shared
- IPV6 (/64 Tunneled - Tunnel endpoint in Sweden)
- 3GB NVME Storage
- Price: £5 Annually
- OpenVZ
 Order Link: https://clients.natvps.uk/index.php?rp=/store/micronode/micronode-nat100m
Micronode nat200m - Our popular NatVPS' come to micronode!
- 256MB RAM
- 5GB NVME Storage
- Price: £6.50 Annually
- OpenVZ
 Order Link: https://clients.natvps.uk/index.php?rp=/store/micronode/micronode-natvps-200m-finland
Terms:
This product is currently in Beta, in the unlikely event that we decide to not proceed with a launch you will be given a full refund and a UK NATVPS for 12 months.
As this is a beta product you may encounter issues, any downtime will be re-reimbursed as additional time until your next invoice period.
These products are automatically setup providing you pass the fraud check - PLEASE USE ACCURATE DETAILS.
We really appreciate anyone that participates in the Beta, all feedback is appreciated.
it means i need a natvpsuk account or i also need invoice history?
There must have been an active service in the past, either via a purchase or a giveaway.
I would like to join, I currently hold a UK node and feel good.
I could do some testing
Managed to install NixOS, pretty standard OVZ experience so far.
A few suggestions:
1. Serial console in case you fuck something up™
2. Considering bandwidth is metered, panel should indicate remaining (please double mine)
Bandwidth isn't metered - I need to change this.
Serial console is something we may add if these prove popular, its a fair amount of dev work which we might never see a ROI on.
I can do it too, bought one uk instance.
Please check my account, the server I purchased earlier has disappeared in the background, but I am still able to connect via SSH.
View Ticket #MJR-361450
can you do a
$ df -h
mine looks like
/dev/ploop21210p1 9.7G 379.0M 8.8G 4% /Anything for you @ehab
Looks like your disk is a few bytes short, mine's:
They are all slightly different sizes, I'm testing
thanks a lot... i never used NixOS , why do you use it? your use cases?
package name/specs are wrong in panel since VPS is having 256mb ram
Thats now fixed, if you re-provision you'll end up with 100m. I won't force you as it was my mistake.
Declarative configuration mainly, so I can version control my infra. Like Ansible-ing your infra, but better.
For example, to configure fail2ban I just need to add this:
One great thing about this is all configuration is in one place so I only have to back up a handful of files (e.g. when doing backups and restores I don't have to remember that the config files should go to
/etc/fail2ban).naah, I'm fine with my 256mb
Maybe if you would have AlpineLinux available since it has a small memory&resource usage
i have a script here
https://gist.github.com/ehab2012/304e11cccd1683099d899e28ab6c4941
first make sure you do before running script
apt-get install curl wget xz-utils apt-utilsYea, I used some script in my Webhorizon's natvps. I would like to see AlpineLinux template in every provider who offers NAT VPS packages since its perfect for those
What's DC?
Finland : AS51765 Oy Crea Nova Hosting Solution Ltd
Ah, Creanova... Thanks!
I had "VDS1-B" (small vps) with them in 2012. The thing which bothered me with Creanova 10 years ago was that IP wasn't geolocated to .FI but .RU or something like that and I wasn't able to use BNC connectivity to .fi ircnet servers while there wasn't any .ru ircnet server, so I cancelled.
They have at least a decent looking website now
yeah, i recall years ago they had some offers in LET but wan't convinced its Finland.
were you always Mumbly? did you have another nic back then?
I could do some testing.
My UK nat invoice id is 300.
It was Finland however IPs in RIPE database belonged to the RU LIR or something like that (they were subsidiary of russian company) hence services which required IP address from .FI ISPs didn't work.
The other. I was away for like 5 years or so (I think) and when I came back it was just quickly/temporarily to find some replacements for few super stable but old and outdated 128/256MB VPSes (from securedragon, xenvzco.uk, weservit, prometeus...) and now I am stuck again
looking glass ?
i am working on a swarm based looking glass... so it might be available soon.
maybe @natvps_uk if he doesn't have an official LG can provide ips.
I'll have one before launch.
I wanted to see only a ipv4/ipv6
someone hammer it with YABS plox
