Good PHP+MySQL Benchmark for Shared Hosting
Hello!
I'm trying to find a good way to benchmark PHP+MySQL performance across various shared providers for comparison sake. I used to have a script I would use for this but apparently in my old age I've forgotten what it was called / how to find it...
Anybody have any suggestions / recommendations?
I am familiar with this for PHP only -> https://github.com/rusoft/php-simple-benchmark-script
But I need something that will benchmark MySQL performance as well [preferably a PHP script that does the testing].
Thanks!
    I find this one to be convenient to use, and I think it gives comparable results for WordPress performance (and yes, it is a WP plugin):
    https://wordpress.org/plugins/wpbenchmark/
    It may not be the most accurate method in the world, but it's pretty precise, i.e. faster-performing providers do get higher results and vice/versa.
    Thanked by (2)Hxxx MikeDVB
    Better than nothing - but I'm trying to find something I can just upload and then fire off via terminal/ssh.
    I can certainly write something myself - but I used to have a script that did all of this for me. Not sure what I did with it!
    Have you checked your floppy disks? 😝
    The 8" or 5.5" disks? I never really considered the hard plastic ones "floppy".
    Thanked by (2)chris bikegremlin
