@legendary said: I would gladly pay even more (~1.99/mo.) for the sake of good quality drama. Majority of us would do the same. When your are in a castle, you need clowns, otherwise it gets boring.
Or you could just try to convince @Nekki to come out of retirement and put on a real show. He is the legend of Low End Entertainment.
I try to stay away from providers that use wood racks, are you planning to upgrade this in the near future?
That's not a rack and it's not made of wood
It's a premium pancake with honeycomb carton inside and laminate at the outside.
Would you please tell me the reason why using this material worries you? I could send this complaint to RD so that our technicians can check better.
My worry is that these types of racks with use will sag over time. If you do not have any plans to upgrade your racks, any chance you might consider silicone injection for your current racks if they start sagging ?
@Flying_Chinaman what is your thinking of the meaning when you call people "chad" ?
Does this come with free datacenter access unannounced?
Plus fridge access, in case I need a snack. If so, I will happly prepay 1 year.
If I am at home yes, can give you coffee or tea and there's also very good takeaway pizza at the side of the house.
I'm wondering if OVH had pizzeria next to their DC
T
There is a fire estinguisher ball to prevent fires.
Reagrds
Don't worry, they're not using wood racks, just wood shelf. Perfectly safe.
Indulge me, what is HIGH QUALITY port?
smartass shitposting satirist
It’s a port of HIGH QUALITY as opposed to low quality, what was it about the statement that wasn’t clear to you?
Alright chad, I am enlightened.
All 65535 ports are equal, but some ports are more equal than others I presume.
Down London way, it's also known as the 'gooch'.
Posh & alpha dude I suppose. Learned from 4chan long ago
