iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
17810121319
  • CalinCalin Hosting Provider
    Hello , @R6gear it s possible leave you email on PM for check
    @jwhan99 for now don t have exactly time , but recommended you no bought if you are aiming to use IPv6
    Regards,
    Calin
  • @Calin said: @jwhan99 for now don t have exactly time , but recommended you no bought if you are aiming to use IPv6
    Mate i think you can use route48 or HE for access ipv6.
    Calin has IPv6 but can't figure out how to get it into Virtualizor.
    He gave me a free KVM that has native IPv6 but no incoming IPv4 ports.
    With the magic of WireGuard, my LowEndSeedbox has both IPv4 and IPv6, and I'm already seeing IPv6 leechers.
    However, IPv6 latency is much higher than IPv4 because the KVM box is on a separate ISP line.
    sunny@box7:~$ ip addr
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state
    UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
        inet6 ::1/128 scope host
    2: venet0: <BROADCAST,POINTOPOINT,NOARP,UP,LOWER_UP> mtu 150
    0 qdisc noqueue state UNKNOWN group default
        link/void
        inet 127.0.0.1/32 scope host venet0
        inet 192.168.100.3333/24 brd 192.168.100.255 scope global
    venet0:0
    3: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1420 q
    disc mq state UNKNOWN group default qlen 500
        link/none
        inet 192.168.121.3333/24 scope global wg0
        inet6 2a02:a58:832d:6700:c8d5:a0b7:105a:3333/128 scope global
        inet6 fe80::ded:2e15:ff78:3333/64 scope link stable-privacy
    Note: a few digits changed.
    Route48 or HE won't be DMCA ignored.
    Hence, if you want IPv6, ask for free KVM and establish tunnel.
    Thanked by (1)R6gear
    HostBrr aff best VPS.
    We are impotent.
  • edited December 2022
    @Calin sorry to ask again, how many days u need to be ready the vps? It's not urgent, just asking and why so long?
  • @R6gear said:
    why so long?
    Clueless administrator.
    Thanked by (1)localhost
    We are impotent.
  • feeling some realy hard diskspeeds now.
    Thanked by (1)tarasis
    Hello @R6gear sorry but i m have lot of working , coming soon VPS Delivery
    @karlo hello , please check now
    Regards,
    Calin
  • Invoice #820 for more ram promotion. Thank you
  • @Calin
    How is that possible, runtime is going back to the past! Unfortunaly there is no recognizable difference in the speed of the disk
    Hello @karlo please give me you invoice number for check problems and fixed , maybe you are limited
    About VPS @R6gear I m delivery now you vps please check , If there are some customers who have not delivered the VPS or what configuration mistake please tell me or open the ticket, I am very glad to help you!
    Regards,
    Calin
  • @Calin
    My invoice is #784
    Thanks for your investigation.
    Regards,
    Calin
    Invoice #826 can you add more 386 ram? if you have a little time to add it :D will be nice.
    Hello @R6gear done you and for other with this tings
    About @karlo , I can confirm do not abuse, but it's an abuser on node, I have now limited this please confirm an improvement of performance, as I said in the future I will solve these things
    Regards,
    Calin
  • @calin the last thing i want it's to enable TUN/TAP to add my self ipv6
    Hello , done @R6gear
    Regards,
    Calin
  • Service was down for exactly 13 minutes each yesterday and today
    Why?
  • @yoursunny said:
    @R6gear said:
    why so long?
    IIRC
    That post has been already claimed by @Not_Oles ?
    Squats are the new Push-ups
    @vyas said:
    @R6gear said:
    why so long?
    IIRC
    Not Oles. By brohost.
    Why?
    Hello @jmaxwell check uptime , node no problems only network problems
    Regards,
    Calin
    Regards,
    Calin
    Happened again, Network problems at your end ?
    Why?
  • Server felt great for me initially and now seems to be capped at 500kb down which kinda sucks...
    Recommended hosts:
    Letbox, Data ideas, Hetzner
    Hello @james50a , please leave me you invoice number for check
    Regards,
    Calin
    Regards,
    Calin
    727
    Recommended hosts:
    Hello , check now please and give me feedback
    Please limited you torrent on 5 MB/s constantly
    Thanks
    Regards,
    Calin
    Thanked by (1)james50a
  • Working, thanks much. Have limited to 4MB to be safe.
    Recommended hosts:
    Hello , who are interesed whit this specifications
    8 GB Ram ddr3 ecc
    KVM Virtualisation
    200 GB HDD with SSD cache and raid 6
    1 dedicated CPU @2.5+ GHz
    16 TB BW/month / 1 GBps port speed
    1x dedicated IPv4
    3 eur/month
    I'm trying to build a cluster of 6 servers with 256 GB ram per server, and I want to know who is interested in such specs , How many people would be interested in buying something like this? I want to say that it will be maximum 32 VM per node
    Thanked by (3)ehab contactwajeeh name
    if you make 2 cores then its super sexy.
    8 GB Ram ddr3 ecc
    KVM Virtualisation
    1x dedicated IPv4
    3 eur/month
    Sounds good as mentioned by @ehab if you can bump the cpu to 2 that will be a sweet deal
    next month, sure. Right now, no.
  • if you make SSD then its super sexy.
