@Calin said: @jwhan99 for now don t have exactly time , but recommended you no bought if you are aiming to use IPv6
Mate i think you can use route48 or HE for access ipv6.
Calin has IPv6 but can't figure out how to get it into Virtualizor.
He gave me a free KVM that has native IPv6 but no incoming IPv4 ports.
With the magic of WireGuard, my LowEndSeedbox has both IPv4 and IPv6, and I'm already seeing IPv6 leechers.
However, IPv6 latency is much higher than IPv4 because the KVM box is on a separate ISP line.
sunny@box7:~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state
UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: venet0: <BROADCAST,POINTOPOINT,NOARP,UP,LOWER_UP> mtu 150
0 qdisc noqueue state UNKNOWN group default
link/void
inet 127.0.0.1/32 scope host venet0
inet 192.168.100.3333/24 brd 192.168.100.255 scope global
venet0:0
3: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1420 q
disc mq state UNKNOWN group default qlen 500
link/none
inet 192.168.121.3333/24 scope global wg0
inet6 2a02:a58:832d:6700:c8d5:a0b7:105a:3333/128 scope global
inet6 fe80::ded:2e15:ff78:3333/64 scope link stable-privacy
Note: a few digits changed.
Route48 or HE won't be DMCA ignored.
Hence, if you want IPv6, ask for free KVM and establish tunnel.
Hello @karlo please give me you invoice number for check problems and fixed , maybe you are limited
About VPS @R6gear I m delivery now you vps please check , If there are some customers who have not delivered the VPS or what configuration mistake please tell me or open the ticket, I am very glad to help you!
Hello @R6gear done you and for other with this tings
About @karlo , I can confirm do not abuse, but it's an abuser on node, I have now limited this please confirm an improvement of performance, as I said in the future I will solve these things
Hello , who are interesed whit this specifications
8 GB Ram ddr3 ecc
KVM Virtualisation
200 GB HDD with SSD cache and raid 6
1 dedicated CPU @2.5+ GHz
16 TB BW/month / 1 GBps port speed
1x dedicated IPv4
3 eur/month
I'm trying to build a cluster of 6 servers with 256 GB ram per server, and I want to know who is interested in such specs , How many people would be interested in buying something like this? I want to say that it will be maximum 32 VM per node
8 GB Ram ddr3 ecc
KVM Virtualisation
1x dedicated IPv4
3 eur/month
Sounds good as mentioned by @ehab if you can bump the cpu to 2 that will be a sweet deal
Hello , @R6gear it s possible leave you email on PM for check
Regards,
Calin
@Calin sorry to ask again, how many days u need to be ready the vps? It's not urgent, just asking and why so long?
Clueless administrator.
feeling some realy hard diskspeeds now.
Hello @R6gear sorry but i m have lot of working , coming soon VPS Delivery
@karlo hello , please check now
Regards,
Calin
Invoice #820 for more ram promotion. Thank you
@Calin
How is that possible, runtime is going back to the past! Unfortunaly there is no recognizable difference in the speed of the disk
Regards,
Calin
@Calin
My invoice is #784
Thanks for your investigation.
Invoice #826 can you add more 386 ram? if you have a little time to add it
will be nice.
Regards,
Calin
@calin the last thing i want it's to enable TUN/TAP to add my self ipv6
Hello , done @R6gear
Regards,
Calin
Service was down for exactly 13 minutes each yesterday and today
Why?
IIRC
That post has been already claimed by @Not_Oles ?
blog | exploring visually |
Not Oles. By brohost.
Why?
Hello @jmaxwell check uptime , node no problems only network problems
Regards,
Calin
Happened again, Network problems at your end ?
Why?
Server felt great for me initially and now seems to be capped at 500kb down which kinda sucks...
Recommended hosts:
Letbox, Data ideas, Hetzner
Hello @james50a , please leave me you invoice number for check
Regards,
Calin
727
Recommended hosts:
Hello , check now please and give me feedback
Please limited you torrent on 5 MB/s constantly
Thanks
Regards,
Calin
Working, thanks much. Have limited to 4MB to be safe.
Recommended hosts:
8 GB Ram ddr3 ecc
KVM Virtualisation
1x dedicated IPv4
3 eur/month
if you make 2 cores then its super sexy.
next month, sure. Right now, no.
if you make SSD then its super sexy.
VirMach: Customer’s Service cannot use more than 10% of the monthly allocated bandwidth in under twenty-four (24) hours.
https://virmach.com/terms-conditions/#aup
