Saturday morning offers
2»
  • @natvps_uk said:
    Hello,
    The payment will have been refunded when your order was marked as fraud, this is usually refunded immediately but can technically take up to 7 days depending on your bank.
    We’re unable to accept any orders that come from a proxy or VPN unless you can provide a form of ID (driving licence, passport, government issued ID card).
    never mind, unfortunately i have to use vpn when im traveling
    i may try again after i back home next month
  • @natvps_uk said:
    It’s not caused any issues so far, they use residential IPs and the end points are fairly close to the clients from what I understand.
    Good to know. The reason I ask is I know one service flagged me as using a VPN because of the Private Relay (MicroLXC). Had to switch from Safari to Chrome.
    I installed OpenConnect VPN server on my home router.
    I can use VPN on my travels.
    All my orders appear to come from my house.
    There's never a problem.
    No hostname left!
  • @natvps_uk, please clear Ticket #HBF-772018, so I can order a few more.
    thanks, will give it a try after i back home
  • AsimAsim OGServices Provider
    Can you define/explain "Loadbalancers" that you offer?
    Sure, the load balancers can be used to balancer HTTP/HTTPS traffic between multiple Virtual servers or instances or as a simple ipv4 to ipv6 proxy.
    Once a loadbalancer has been created you are returned an endpoint address which you simply point a cname to.
    SSL is provided automatically via lets encrypt.
    Thanked by (1)tenpera
  • @natvps_uk said:
    These are on the instances platform only, most of our new locations will follow this route.
    2bad... thanks anyways
  • @natvps_uk please help, can't login to MicroNode control panel. Ticket CYM-873130
    We will take a look at this asap.
