@pan21 said: @natvps_uk Hi, I just placed an order, invoice #1075, my card has been charged, but system flag my order as fraud.
I'm currently on holiday until mid Jan, and have to use VPN to access internet.
Can you please look into it? please set up the micronode I ordered, or refund my payment, thanks
Hello,
The payment will have been refunded when your order was marked as fraud, this is usually refunded immediately but can technically take up to 7 days depending on your bank.
We’re unable to accept any orders that come from a proxy or VPN unless you can provide a form of ID (driving licence, passport, government issued ID card).
never mind, unfortunately i have to use vpn when im traveling
i may try again after i back home next month
@tarasis said:
I’m curious how Apple’s Private Relay feature plays an issue for you. It’s not quite a VPN, not quite a proxy, but does mask your origin IP. Does it mean more work for youse?
(Pretty sure it was active when I got my BF deal)
It’s not caused any issues so far, they use residential IPs and the end points are fairly close to the clients from what I understand.
Good to know. The reason I ask is I know one service flagged me as using a VPN because of the Private Relay (MicroLXC). Had to switch from Safari to Chrome.
I installed OpenConnect VPN server on my home router.
I can use VPN on my travels.
All my orders appear to come from my house.
There's never a problem.
No hostname available. affbrr
@natvps_uk, please clear Ticket #HBF-772018, so I can order a few more.
thanks, will give it a try after i back home
Can you define/explain "Loadbalancers" that you offer?
Sure, the load balancers can be used to balancer HTTP/HTTPS traffic between multiple Virtual servers or instances or as a simple ipv4 to ipv6 proxy.
Once a loadbalancer has been created you are returned an endpoint address which you simply point a cname to.
SSL is provided automatically via lets encrypt.
2bad... thanks anyways
@natvps_uk please help, can't login to MicroNode control panel. Ticket CYM-873130
We will take a look at this asap.
