iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
18911131419
  • @Calin said:
    Hello , who are interesed whit this specifications
    8 GB Ram ddr3 ecc
    KVM Virtualisation
    200 GB HDD with SSD cache and raid 6
    1 dedicated CPU @2.5+ GHz
    16 TB BW/month / 1 GBps port speed
    1x dedicated IPv4
    3 eur/month
    I'm trying to build a cluster of 6 servers with 256 GB ram per server, and I want to know who is interested in such specs , How many people would be interested in buying something like this? I want to say that it will be maximum 32 VM per node
    How about
    2GB RAM,
    500 GB HDD,
    1 Dedicated IPv4
    €1.5/m
    1GB RAM,
    256 GB HDD,
    1 Dedicated IPv4
    €1/m
    Why?
  • @Calin
    Invoice # 857
    Please check my order which is now pending and add ram to it. Thank you so much.
  • invoice:863
    Paid
    transaction number:9VR88395XM5820812
  • Hello @naiba and @eggroll done , thanks for choice iHostART :D
    Regards,
    Calin
  • Hello @Calin,
    any chance you could enable TUN on the/my server?
    Oh and btw, order ID: #9729345869 invoice ID: #856
    Regards
  • edited December 2022
    Hello sir , done
    Regards,
    Calin
    About @jmaxwell unfortunity it s very very cheap , and no good with IPv4 dedicated very sorry :(
    Regards,
    Calin
    Thanked by (1)schnafi
  • @Calin
    Invoice #876.
    Please increase the ram,thanks.
    Machine is offline since 5 hours ago.
    No TV this morning.
    Thanked by (2)lemoncube jmaxwell
    No TV this morning.
    So it’s not just me.
    Why?
    No TV this morning.
    @TrendyJack said:
    No TV this morning.
    yes ,10 hours down
    update
    its up now
  • Hello everyone very sorry , now all working good
    Regards,
    Calin
  • 11 hr downtime hmm…glad I paid only €5.5/yr
    Why?
  • Hello , very sorry but network problems for LV0 node , this type of packed don t have backup network
    Please check https://uptime.ihostart.com other node don t affected
    Regards,
    Calin
  • Order number confirmed: 9621171355
    @Calin , asking for additional RAM. Thank you!
  • @Calin
    could you also help check this one? I already have paypal transaction id 2TA7956262215040U but in member area it says not paid yet, from Invoice #908 (hopefully it's just the usual paypal delay)
  • Is there a tutorial to setup torrents on nat vps? Appreciate any help on this..
    • install qbittorrent-nox from repo, enable the service if applicable
    • configure it following docs, set webui listen port to one of the 5 ports assigned to your vm (you can save a port by assign a different one when you use reverse proxy for all your http/s services)
    • click gear icon in webui, set port to another assigned port under connection tab
    • add a torrent and start downloading
    • on the lower right towards the middle of webui, if you see a yellow plug icon turning into a green globe then you're good to go
    Thanked by (2)Calin mee2
    This is unsafe.
    Pick a non-mapped port and listen on 127.0.0.1 only.
    Access the WebUI via SSH tunnel.
    Thanked by (2)lemoncube mee2
  • @yoursunny said: Access the WebUI via SSH tunnel.
    I use randomly generated string as subfolder for reverse proxy and hope no one could guess. :#
    This is unsafe.
    What’s the worse that could happen ?
    Why?
  • @jmaxwell said:
    This is unsafe.
    Hacker connects to your LowEndSeedbox and deletes torrents.
    Private tracker sees HnR and bans your account.
    Hacker connects to your LowEndSeedbox and uploads kiddy popcorn content.
    You have to discuss this matter in Romania courts.
    @jmaxwell said:
    This is unsafe.
    Well that would suck
    *for Calin
    Why?
  • AuroraZeroAuroraZero ModeratorHosting Provider
    I guess I shall never understand any of it.
    If you want to go the extra safe route, run qbittorrent-nox in a Docker container, run OpenVPN-client or Wireguard-client in another container.
    Use network_mode: container:yourvpnclient on qbittorrent to force the connection through an OpenVPN server, qbittorrent wont be able to connect to the internet unless the OpenVPN connection is made, prevents leaking anything traceable.
    Edit: then access the WebUI via SSH tunnel or Cloudflare for persistent access.
    lex.st - Free Shared Hosting in 4 Locations. fk ipv6.
    Doesn't the hacker need to compromise the web interface password to accomplish any of this? It seems most seedboxes use a torrent client this way. Assuming the password doesn't suck it sounds like a very low risk scenario, though I agree that moving to an ssh tunnel secured by ssh key is the most secure option.
    Hello please leave invoice number , go on Client Area > Invoices
    Regards,
    Calin
    HTTP: your password is on the wire.
    HTTPS: it's secure, but getting a certificate without port 443 is difficult.
    Just get a real domain and use DNS verification method for certbot
    Thanked by (3)FrankZ lemoncube morreke
    Why?
  • Invoice #911
    Emergency call for additional memory.
    And price for getting that number @Calin ?
