12526283031357
  • FrankZFrankZ ModeratorOG
    edited January 2023
    @alexxgg said:
    Yes, I knew that already after the troubleshooter debug data.
    No, the service was activated 24 hours after the payment, it appears offline since its activations.
    The service was ordered on December 24, activated on December 25. only thing I've tried was power it on, via Virmach user panel and minutes later, via Solusvm control panel. None of both seems to work.
    Yes and I believe the recreation of the VM will fix the issue, instantly.
    Don't mind to share VM information.
    Thanks for getting back to me with all the info. You seem to have run thru the checklist under the yellow "Issue New Service" button and it still does not even show online. I expect you are correct and Virmach will need to fix or recreate your VM on his end. I have one that I recently purchased on PHXZ001 with similar issues. I personally have not made a ticket for this as I expect that it will be taken care of automatically as VirMach make his rounds checking that all the VMs created properly. However I am not in a rush for provisioning, and you are, so I completely understand why you ticketed regarding this issue.
  • Has anyone noticed that the initial disks images for Virmach VM's contain a pre-existing image?
    1. Select 'Install Later' when purchased
    2. Boot into Rescue instead of installing an O/S
    3. Examine /dev/vda and notice there's data: "Jun 9 01:08:47 OblongUnnatural-VM ... "
    LIMITED OFFER
    $7.95 /yr
    KVM – 1 GIGABIT
    868MB DDR4 RAM
    1 vCORE (RYZEN 3.4GHz+)
    35GB SSD (NVMe)
    3584GB MONTHLY DATA
    NYC METRO, NJ LOCATION
    1 DEDICATED IPv4
    edited January 2023
    Can you show some screen shots of what you are saying in #3.
  • @VirMach said:
    Very high "you fixed my computer and now every time it breaks it's because of the thing you did 3 months ago" vibes. Not everything is related in the same exact way. This time it's even worse.
    But if it is hardware broken for the disk,maybe you better consider to change not fix.
    Just for example
    Thanked by (2)FrankZ root
  • @FrankZ said: Thanks for getting back to me with all the info. You seem to have run thru the checklist under the yellow "Issue New Service" button and it still does not even show online. I expect you are correct and Virmach will need to fix or recreate your VM on his end. I have one that I recently purchased on PHXZ001 with similar issues. I personally have not made a ticket for this as I expect that it will be taken care of automatically as VirMach make his rounds checking that all the VMs created properly. However I am not in a rush for provisioning, and you are, so I completely understand why you ticketed regarding this issue.
    Thanks for sharing that information. I'll wait and hope for the service come online during this month. When the issue is finally fixed, I'll post about it.
  • JabJab Senpai
    $22.01 /yr
    KVM – 1 GIGABIT
    3929MB DDR4 RAM
    3 vCORE (RYZEN 3.4GHz+)
    55GB SSD (NVMe)
    5632GB MONTHLY DATA
    CHICAGO, IL LOCATION
    2 DEDICATED IPv4
    This was nice =)
  • how'd you use these 'limited offer' ?
    I'm looking for 4GB ram vps, but to see 2 dedicated ipv4, why?
    You can buy limtied offer from bottom link
    https://virmach.com/flash-sale/
    Thanked by (1)Encoders
    Nan, go to customization, choose the spec ya want
    https://virmach.com/black-friday-cyber-monday/
    Thanked by (2)jacky06046 Encoders
    Ontario Dildo Inspector
    Whaaaaaaaaaaaaaaaagh 2expensive4me on 4gig ram
    thanks, will keep an eye on this.
    this is my 'stuff' in 2core4gb ram so i figure i could place this in a vps
    but well, probably will trying inside a vm first so i don't get f<3<3ked by the tos yadayada
    Thanked by (1)jacky06046
  • JabJab Senpai
    $6.29 /yr
    KVM – 1 GIGABIT
    985MB DDR4 RAM
    20GB SSD (NVMe)
    2048GB MONTHLY DATA
    1 DEDICATED IPv4
    6.29!
    Thanked by (1)localhost
  • edited January 2023
    @Jab said:
    $6.29 /yr
    KVM – 1 GIGABIT
    985MB DDR4 RAM
    20GB SSD (NVMe)
    2048GB MONTHLY DATA
    1 DEDICATED IPv4
    6.29!
    Low spec no brainer, one of the best so far
    MJJ rating 145% worthy
    Just an FYI the customized VPS show the price for one year on the customizer, but that is actually the price for two years. When you click thru to the next page it should show the price Biennially (every two years.)
    Thanked by (1)ariq01
    edited January 2023
    LIMITED OFFER
    $7.77 /yr
    KVM – 1 GIGABIT
    768MB DDR4 RAM
    35GB SSD (NVMe)
    3584GB MONTHLY DATA
    AMSTERDAM, NL LOCATION
    1 DEDICATED IPv4
    No Brainer!
    Thanked by (1)noisycode
  • @FrankZ said:
    LIMITED OFFER
    $7.77 /yr
    KVM – 1 GIGABIT
    768MB DDR4 RAM
    35GB SSD (NVMe)
    3584GB MONTHLY DATA
    1 DEDICATED IPv4
    Europe is awake now
    @localhost said:
    Europe is awake now
    *Woke Woke Woke*
    MJJ rating 117% worthy
    Flash Sale have better formula :-)
  • JabJab Senpai
    @localhost said: Europe is awake now
    Perfect time @VirBOT - it's not like it's 3-5 AM in Europe now :trollface:
    Thanked by (2)localhost AlwaysSkint
  • When I had a VM with VirMach it idled for a whole year. Reinstalled a few times, had to open a ticket to get those windows reinstall done (part of the instructions they gave at the time).
    Never used for production, specially due to the fair share policy. I cant run stuff with fear of having something suspended. I prefer to just pay dedicated servers or VM with dedicated cores that I can blast 24/7.
    But I bet it would be a good VPN or jump box. Would use for stuff like that for sure. Or if dedicated cores were available as addons in the special offers.
  • That AUP of VirMach:
    "High I/O: Customer’s Service cannot average more than 80 IOPS within any two (2) hour period"
    Is that a misprint?
  • JabJab Senpai
    edited January 2023
    @hornet said: Is that a misprint?
    Yes and No. Those are old HDD limits, VirMach said they need to update those and they have much higher limits for kill-scripts now... but it's still there so can be used against you! ;')
    However I don't recall anyone coming here (or there) complaining about "I was unjustifiably suspended" except few abusers that (like the one in this thread earlier that went nuts and because he did not use whole bandwidth he thinks it was okey :D)
    When it reach 7T of 8T , I stop this service, but still suspended by virmach (...)
    He managed to use 7TB of bandwidth within 2 days while going nuts on disk and he thinks it's okey :D
    https://lowendspirit.com/discussion/comment/120289/#Comment_120289
  • @saibal said:
    Are you going to transcode?
    Do you have any experience one way or the other?
    i see, I'll check again if it's really cheaper in biennially term
    anyone running billion dollar business with virmach here? I'm sure there are one or two. praise the $7
    edited January 2023
    LIMITED OFFER
    $18.68 /yr
    KVM – 1 GIGABIT
    4340MB DDR4 RAM
    25GB SSD (NVMe)
    2560GB MONTHLY DATA
    SEATTLE, WA LOCATION
    1 DEDICATED IPv4
    @Encoders
    Thanked by (2)Encoders noisycode
  • @FrankZ said:
    delivered within an hour of purchase, however, in some cases, it may take longer.
    LIMITED OFFER
    $18.68 /yr
    KVM – 1 GIGABIT
    4340MB DDR4 RAM
    25GB SSD (NVMe)
    2560GB MONTHLY DATA
    1 DEDICATED IPv4
    @Encoders
    [[Screams Externally]]
  • I did transferred my VPS 4x4x100 from NL to DE. Working good. And network work good. Performance better than on NL.
    root@s1:~# curl -Ls benchy.pw | sh
    #             Benchy v2.5               #
    #    https://github.com/L1so/benchy     #
    #        04 Jan 2023 03:59 UTC          #
    Server Insight                                  Hardware Information
    OS         : Ubuntu 20.04.5 LTS                 Model       : AMD Ryzen 9 5900X 12-Core Processor
    Location   : Germany                            Core        : 4 @ 3693.060 MHz
    Kernel     : 5.4.0-135-generic                  AES-NI      : ✔ Enabled
    Uptime     : 0 days, 0 hrs, 2 mins, 41 secs     VM-x/AMD-V  : ✔ Enabled
    Virt       : kvm                                Swap        : 0.0 KiB
    Disk & Memory Usage                             Network Information
    Disk (1)   : 100.1 GiB                          ASN         : AS3214
    Disk Usage : 3.0 GiB (3% Used)                  ISP         : xTom GmbH
    Mem        : 3.8 GiB                            IPv4        : ✔ Enabled
    Mem Usage  : 0.2 GiB (4% Used)                  IPv6        : ✔ Enabled
    Disk Performance Check (ext4 on /dev/vda2) (R: Read, W: Write, T: Total)
    | Size | Read        | Write       | Total       |       IOPS (R,W,T)       |
    | 4k   | 482.38 MB/s | 483.65 MB/s | 966.03 MB/s | 123.5k | 123.8k | 247.3k |
    | 64k  | 1.63 GB/s   | 1.64 GB/s   | 3.28 GB/s   | 26.8k  | 27.0k  | 53.8k  |
    | 512k | 2.30 GB/s   | 2.42 GB/s   | 4.73 GB/s   | 4.7k   | 5.0k   | 9.7k   |
    | 1m   | 2.60 GB/s   | 2.77 GB/s   | 5.37 GB/s   | 2.7k   | 2.8k   | 5.5k   |
    Network Performance Test (Region: Mixed)
    | Prot. | Provider    | Location        | Send         | Receive      | Latency   |
    | IPv4  | Airstream   | Wisconsin, US   |    1.7 Gb/s  |  399.9 Mb/s  |  105.0 ms |
    |       | Uztelecom   | Tashkent, UZ    |   55.6 Mb/s  |  742.8 Mb/s  |   75.6 ms |
    |       | Novogara    | Amsterdam, NL   |    1.9 Gb/s  |    1.9 Gb/s  |    8.6 ms |
    |       | FiberBy     | Copenhagen, DK  |        busy  |  951.3 Mb/s  |   22.2 ms |
    | IPv6  | Airstream   | Wisconsin, US   |    1.5 Gb/s  |  668.0 Mb/s  |  105.2 ms |
    |       | Uztelecom   | Tashkent, UZ    |    1.5 Gb/s  |  792.2 Mb/s  |   73.5 ms |
    |       | Novogara    | Amsterdam, NL   |    1.9 Gb/s  |    1.8 Gb/s  |    8.7 ms |
    |       | FiberBy     | Copenhagen, DK  |    1.9 Gb/s  |        busy  |   17.5 ms |
    | Geekbench 5.4.5 Tryout for Linux x86 (64-bit) |
    | Single Core        | 1505                     |
    | Multi Core         | 4941                     |
    | https://browser.geekbench.com/v5/cpu/19687505 |
    | Benchy time spent  | 5 Minutes 30 Seconds     |
    | Benchy result      | http://sprunge.us/KNfOcu |
    Thanked by (2)lemoncube noisycode
  • @FrankZ said:
    LIMITED OFFER
    $18.68 /yr
    KVM – 1 GIGABIT
    4340MB DDR4 RAM
    25GB SSD (NVMe)
    2560GB MONTHLY DATA
    1 DEDICATED IPv4
    @Encoders
    I've got one! A baby monster, sort of. :P
    | Multi Core | 4941 |
    IMPRESSIVE!
  • LIMITED OFFER
    $29.78 /yr
    KVM – 1 GIGABIT
    2730MB DDR4 RAM
    4 vCORE (RYZEN 3.4GHz+)
    135GB SSD (NVMe)
    13824GB MONTHLY DATA
    DALLAS, TX LOCATION
    3 DEDICATED IPv4
