@HuangxinYuan said:
When it reach 7T of 8T , I stop this service, but still suspended by virmach after a week. If virmach limited network , It should list detail rules, and should not just suspended it without any warning msg, and even not rely TK for 3 month.
It is not about the quota but the network speed / bandwidth, you do realize the total bandwidth available in a single node (that hosts tens or hundreds of VPS) is 1Gbps right? This means at the same time your neighbor in the same node will get poor connection speed
I am not sure about why the ticket is not replied or got suspended without warning, but I would recommend throttle a bit when you run your application in the future
So the user's VPS of Virmach can be shut down without any clear indication, and even without the possibility to access the data. I don't know of any other IDC besides Virmach that would dare to treat their customers this way. Maybe only in Virmach.
Yes. Not maybe. Virmach is the only one.
You should stay away from Virmach. You also have to warn your friends on the mainland to stay away from Virmach.
Don't listen to those defending posters in this forum.
They are actors that get paid to shill Virmach.
Yo I have not received my store credit yet
Boycott sweatshop Virmach
It seems SEAZ002 is suffering from network issue. The average load of SEAZ002 is approx. 1.0, much lower than any other host (approx. 6.0~16.0). And the network TX drops to the deadly 256kbps.
Yea, virmach knows about it. Was reported on the 2nd I believe. A few of us have a limited offer vps there and cant ssh into it.
Wrong language. You need to write in England English.
(Seeing as it's a Stateside bus and their/your pronunciation makes more sense - just - I'll let ya off! )
What I am really expecting is to run a GB5 on it, and I bet the score sooooooars.
@VirMach
Having a server offline (so far 6+ hours) effecting multiple users does deserve at least the status page being updated to say there is a problem.
You don't want lots of tickets opened and yet you create a situation which will encourage their creation.
Totally appreciate you are likely (hopefuly) dealing with this but informing - even if a single line message - should be a priority.
And your status page says
Also posting this message to show that even the supposed 'paid shills' (previous MJJ comments) are capable of saying when there is a problem or saying when things are going well.
hmm, my service on DALZ008 DHCP keeps returning 192168.77.11 on the VPS, I wonder if someone is running a DHCPD on their VPS...
correct cutout this time.
Ontario Dildo Inspector
I actually have traveled once in the WRTA Worcester route 29... albeit over 7 years ago.
Good times 😅😎
So when does Europe wake up?
Starting from 6AM, granted I was awake at 4AM but this was due to my fucked sleep rhythm.
ITS WEDNESDAY MY DUDES
Wuss-ter!
This is good or bad? Yo no comprendo
Wrong language. You need to write in MJJEnglish. Then you might understand when they reply.
Stop the planet! I want to get off!
Nopes
It's wor--ches-ter
Is the 29 the only bus in Worcester?
My $8.88 vps from the 23rd got activated and date moved from the 23rd to Jan 3rd, yay!
if i may ask, what location is it?
Mine is set "Active" as well but when I click it, it shows "Virtual server not found"
Frankfurt, got put on FFME004
It gave me that error the first time but then second time I clicked on it, it worked.
It's dead as a can o' spam, to me; not even the gateway is pinging. 'Tis untraceable - literally.
Same here, can't get connect.
Ooh, looks like something's happening with the SEAZ002 node.
Nah, wishful thinking: I put the VM offline manually, yesterday. Drat!
it is almost bed time, and I have not bought a single server today!
congratulation
Can someone please confirm if there are any US locations that support Netflix?
Test IPv4 Result Only
bash <(curl -L -s https://git.io/JRw8R) -E -M 4
Test IPv6 Result Only
bash <(curl -L -s https://git.io/JRw8R) -E -M 6
none do
@VirMach
Plan B: get another VM on SEAZ00X as a jumper server.
I've got myself one and it works well.
and I could not resist.
