Managed with offsite backups (just someone to do it for me and take the hassle out of it)
Can anyone help?
Thanks
Chip
Virtual server with 2 vCore CPU, 4GB RAM, 100GB HDD, 10TB @ 2Gbps bandwidth, 100Gbps anti-DDoS protection, dual stack IPv4/IPv6 network, and various services including load balancer, IP failover, vSwitch, backup, firewall, and snapshots. Option to add additional network interface via SIIX peering port.
€6,56/month
What type of managing do you need?
Can anyone help?
Thanks
Chip
€6,56/month
I want someone to do the setup/ hand holding (day-to-day management) for me... its only going to be for me and a few friends/family (at worst)
Can anyone help?
Thanks
Chip
€6,56/month
It's something we can provide at a low fee, please DM me.
Can anyone help?
Thanks
Chip
€6,56/month
I strongly recommend that you separate the VPS provider and the offsite backups to two independent entities. I would also verify the restore process before you go live. It is no fun to troubleshoot restore issues while the system is down. Just ask the FAA about NOTAM. :-(
What location
Doesn't really matter... im in the UK so somewhere with good/acceptable connectivity to there
https://www.clouvider.com/managed-hosting/
The next in line to the throne.
€6,56/month
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
Hello @chip try https://panel.ihostart.com/index.php?rp=/store/ddr3-ram-vps unfortunity it s unmanaged VPS but create a cron-tab for automatically update
Regards
Calin
I was looking around before I set up my own Soapbase (Pleroma) instance and had those two saved in my bookmarks:
Didn't try any of them though, so can't provide any more information...
As a provider what did you just tell him to do?
wot
The problem you will run into is not the cost of the server it is the cost of the Admin to do it.
Most management of this type of thing does not come cheap and if it does you will likely not like the outcome.
Someone available 24/7 to do maintenance and fix broken things is a hot commodity now a days.
Indeed; to be honest you're probably better off looking for a dedicated mastodon hoster (I think masto.host are open again) rather than a managed VPS.
Another option to consider (if you're comfortable suckling at Cloudflare's teet) - https://github.com/cloudflare/wildebeest
I've DM'd you
Thanks
Chip
